CAE Adjustable DSSR
  • Kershaw
    • 11822
    CAE Adjustable DSSR
    6OVRCRST Polycarbonate Rear Windows Subaru Impreza Coupe High quality abrasion resistant polycarbonate rear windows for your rally car!
    Wish I had known about this, I would have used it instead of having mine extended and welded. Which Im sure is fine, but still...
    Just passing this along.
    AWD > RWD
    • 34839
    personally I'd rather have something that is fixed in this case, rather than adjustable - you wouldn't want it to come loose or something. it's not exactly easy to get to, and it's not like you really need to adjust it more than once.
    looks like a nice product though.
    • Kershaw
      • 11822
      I hear what you're saying, but that type of clamp is fairly common in the auto industry. Hell, our tie rods use it. A little locktite and I'd doubt that bolt is going anywhere.
      AWD > RWD
        • 34839
        the issue is that the selector rod has to take torsion. a tie rod only has to take tension and compression, which is why that joint works fine.
        I don't know if it's threaded but I hope not. It looked like a compression joint, but it could still slip and move. Maybe it has holes or something to lock it in place.
        I do like that it comes with the selector rod joint though.
        • monkey_boy
          • Sep 2015
          • 102
          I suppose you could set it at the length you want, toss the clamp and weld in place.
          • Kershaw
            • 11822
            Doesn't look like it. https://www.quora.com/Is-Aluminium-7075-T6-weldable
            AWD > RWD
            • The Dark Side of Will
              • Jun 2010
              • 2796
              I don't see any indication that either the OD of the male part or the ID of the female part are threaded. It looks like a smooth slip fit held by the clamp.
              Yes, that clamp will hold all the tension and torque spindly little human arms are capable of generating.
              • burkey001
                • Feb 2011
                • 608
                that is a nice looking part for sure
                88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                  • 34839
                  well I don't know about you but I can put a lot of torque on something with one hand especially with a 12:1 leverage ratio. ;)
                  it might be OK but it's not something I would personally want in my car, it's such a pain in the ass to get to if it ever did slip or come loose. it's not difficult to have it modified and it's about the same price, so why bother?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    What is the point of this? Why would you want it adjustable?
                    • kronus
                      • Apr 2008
                      • 13032
                      fuh raze
                      cars beep boop
                      • ak-
                        • 12422
                        tack weld it after adjustment.
                        show them all you don't care.
                        1991 325iS turbo
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Just drill a cross hole and put a split pin in it. Then you can take it apart if needed.
                          • Kershaw
                            • 11822
                            I would assume to compensate for the differences in non stock engine and transmission combinations.
                            AWD > RWD
                            • Jake D
                              • 60
                              We sell a lot of these along with the CAE Ultra Shifter. We use it in our own S54'd E36 and E46M3 and it has never come loose. I can't even think of a case where this has happened.
                              In your average street car, the adjustability is not necessary. In a custom track-built race chassis sometimes having the option to "reposition" the placement of the shifter to best suit the driver position is desired. When you're using an extended shifter like the CAE, it's best to get the knob positioned in such a way that suits your personal quirks and preferences. Hey, race drivers are pretty particular about such things.
                              (HARD Motorsport GM)
                              5erWest <--- click it.
