New way to space front drive shaft?
  • driftxsequence
    • Apr 2015
    • 203
    So this weekend I pulled my transfer case to do the shift bushings, and came across this piece. It appears a previous owner has already shimmed the front driveshaft without requiring a new quibo. The driveshaft has a long threaded "set screw" and a standard nut at the other end near the differential flange. This method may be cheaper, or easier for future use? Maybe its worse and I just dont know it? You tell me
    picture of the threaded set screw
    325IX Build Thread
    RX7 Build Thread
  • The Dark Side of Will
    • Jun 2010
    • 2796
    Are the set screws welded into the fingers of the driveshaft flange?
    • driftxsequence
      • Apr 2015
      • 203
      nope, i use the allen head to thread them in while holding the nut in place otherwise when the stud is fully seated there would be no room to slide the nut on. a bit more tedious, but it works.
      325IX Build Thread
      RX7 Build Thread
      • flyboyx
        • 8371
        So.....someone threaded the holes in the driveshaft flange to accomodate the set screws? I wonder if they welded the holes and redrilled them to a smaller diameter? Or perhaps installed hellicoils? Its an interesting idea. What is the grey stuff on the ends of the studs? Epoxy?
        Gigitty Gigitty!!!!
        • driftxsequence
          • Apr 2015
          • 203
          The grey stuff is antiseize. I can pull one back out yo measure the diameter but it appeared to be the same size as everything else. The shaf lt did not appear to be welded.
          325IX Build Thread
          RX7 Build Thread
            • Jun 2010
            • 2796
            The set screw has to be the same diameter as the original guibo bolt or it wouldn't go through the guibo... so yeah, something fancy was done to make those screws thread through the holes in the driveshaft flange, because those are clearance holes as delivered by BMW.
              • 34837
              Seems like a lot of work when a thicker flex disc will also be tougher than the original one, and you need one anyway.
              • driftxsequence
                • Apr 2015
                • 203
                Holy cow the front flex disk is pricey compared to the rear...wow.
                325IX Build Thread
                RX7 Build Thread
                • flyboyx
                  • 8371
                  I would use the thicker guibo instead of the custom spacer, but the allen studs are a great idea in that you dont need to clearance the oil pan.
                  Rather than anti seize, i would use locktite.
                  Gigitty Gigitty!!!!
                    • 34837
                    it's not the oil pan really - just a dust cover. Will has some pretty cool pics of his machined down.
                      • Jun 2010
                      • 2796
                      That's one of the incentives for swapping to the thicker one.
                        • 34837
                        I kind of wish I had a good standard length shaft now instead of the extended ones. They work great but it's such a pain to remove because you have to pull the entire T-case.
                        Does the dust cover on the transfer-case end of the front shaft still snap into place?
                        • Kershaw
                          • 11822
                          What's the shim made out of? Milled aluminum?
                          AWD > RWD
                          • driftxsequence
                            • Apr 2015
                            • 203
                            Yes it does!
                            Yes it appears to be milled aluminum.
                            Again, I've owned the car for about a week so I'm learning and can get more info next time I roll under the car....which will be a week or two once the rear guibo gets replaced. the front doesnt look THAT bad...compared to the rear!
                            325IX Build Thread
                            RX7 Build Thread
                            • mw044
                              • Dec 2008
                              • 59
                              I've used this method in my ix. I made the spacer from another driveshaft flange. Just machined the centering grooves on the other side. Later I installed "jute91" longer splines in the rear of the shaft. Never had one single problem with the front driveshaft.
