New way to space front drive shaft?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    Originally posted by nando
    I kind of wish I had a good standard length shaft now instead of the extended ones. They work great but it's such a pain to remove because you have to pull the entire T-case.
    Does the dust cover on the transfer-case end of the front shaft still snap into place?
    If you have an extended spline fitting, you can still convert to a split shaft like I did for my dad's car ;)
    Yeah, the dust cover (grease retainer?) just snaps in. There's a snap ring on the outside of the T-case sprocket snout.
    • Kershaw
      • 11822
      Do you really have to drop the T case to remove the jute91 extended shafts?
      AWD > RWD
        • 34839
        yes. or the front diff, but the transfercase is easier, lol.
        Fortunately he gave us a grease nipple so there's not a lot of reason to remove it.
        • audiquattrot
          • May 2008
          • 3836
          i have this exact spacer in my ix w the same screws. Its' made my Moonlite Motorworks in PA.
          www.instagram.com/snwmble
          #snwmble
          Current:
          '05 BMW M3 - Silver Grey/Imola Red
          '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
          '15 Mini Countryman - Blazing Red/Carbon Black
          Past:
          '01 Audi Allroad - Light Silver/Platinum Saber Black
          '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
          '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
          '90 BMW 325i - Schwarz/Tan sport *Sold*
          '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
          • audiquattrot
            • May 2008
            • 3836
            here's the link
            http://www.moonlitemotorwerks.com/driveshaft
            #snwmble
            Current:
            Past:
            • driftxsequence
              • Apr 2015
              • 203
              Awesome! Thanks for clearing that up.
              325IX Build Thread
              RX7 Build Thread
              • audiquattrot
                • May 2008
                • 3836
                no prob. They had to modify my existing front driveshaft to thread.
                It has held up great throughout the last 4yrs i've been running it.
                #snwmble
                Current:
                Past:
                • audiquattrot
                  • May 2008
                  • 3836
                  I just noticed the pic on the Moonlite link I put up looks to be he same as your car. Has a green marking on the driveshaft. I wonder if your car is the same one that they used on their site
                  #snwmble
                  Current:
                  Past:
                  • driftxsequence
                    • Apr 2015
                    • 203
                    Ill check to see if i have a matching serial number by the shaft.
                    325IX Build Thread
                    RX7 Build Thread
                      • 34839
                      The thing I don't like about that spacer is it doesn't have the centering pin for the differential. It may be OK to rely on the bolts to center the driveshaft, but there's a good risk of vibration. I'd also worry about it putting a bit more wear on the splines if it's not aligned correctly.
                      And with the X5 centering pin you also get a stronger guibo.
                      • driftxsequence
                        • Apr 2015
                        • 203
                        Mine still had the centering pin
                        325IX Build Thread
                        RX7 Build Thread
                        • Kershaw
                          • 11822
                          I have the same green marking on my front driveshaft. Wonder what they mean.
                          AWD > RWD
