iX rear sway same as normal e30?
  • BimmerScreamer
    • Dec 2008
    • 413
    So I'm looking to put a bigger rear sway in my iX and I'm wondering if it has to be iX specific?
    Anything can be done
  • dr.strangelove
    • Jan 2005
    • 847
    rear, no.
    front, yes.
    • BimmerScreamer
      • Dec 2008
      • 413
      thanks
        • 34839
        Originally posted by dr.strangelove
        rear, no.
        front, yes.
        you have it backwards
        rear is the same as the stock E30 M3
        front is unique - there is no aftermarket.
        • BimmerScreamer
          • Dec 2008
          • 413
          so if I want to upgrade mine do I need to get one that says its for a normal e30 or m3, none say they will work on the iX but is the rear of the iX all the same as other e30's?
            • 34839
            yes, you can use any E30 rear swaybar on your ix.
            I'd probably go for an H&R 18mm or ST 19mm. avoid anything too big (like the IE 22mm) since you have to leave the front stock.
            • ShowStopper
              • Jan 2008
              • 1845
              ix and m3 rear sways are the same size
              all other e30s are smaller
              • BimmerScreamer
                • Dec 2008
                • 413
                what is the ST 19?, whats the problem with the 22?
                my last mini handled like an animal and had a 25.5mm rear and factory front among other things (not sure how much of that carries over to an awd)
                  • 34839
                  22mm is too big. it's going to make the car very tail happy, especially in the wet/snow.
                  ST is Suspension Techniques
                  • Alkasquawlik
                    • 4557
                    bumping this from the dead, what is the advantages of having an aftermarket rear sway? improving chassis rigidity?
                    SC*AR
                    Originally posted by JamesE30
                    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
                      • 34839
                      less roll, less understeer/more oversteer.
                      • Alkasquawlik
                        • 4557
                        Are you running one in your car? And if you are, what kind?
                        SC*AR
                          • 34839
                          no, mine are stock. I never really felt like it was something I needed to upgrade.
