325ix front wheel shake, and clunking over bumps
  • rwtags
    • Aug 2018
    • 208
    I have a 91 325ix with 219k, i get a weird shaking at exactly 50mph while crusing. I also have a clunking when going straight over bumps from only the passenger side, it seems to not clunk while i am slightly over bumps with the brakes on, but i dont know if that is true or not. Doesnt matter when i turn over bumps or not. I have gotten under the car and replaced the passenger side sway bar mount, and i have new bushings for the sway bar are on the way. What are some things i can check for, i got under the car and was pushing things around but nothing seems to clunk.
    I have read that the subframe bolts could be loose, do you think this is a possibility?
    • 34844
    control arm bushings, ball joints, tie rods, strut mounts..
    If you have loose subframe bolts, something is really really wrong. They are huge and really tight.
    • rwtags
      • Aug 2018
      • 208
      Control arm bushings where just replaced today, made some change but still there is a slight clunk on passenger side, the rods are tight, no play, must be somethijng strut related. There is still no source for inner the rods on ix?
      Edit; just check strut nut on top, the thing is just spinning like there is no thread engagement. I have new strut hats, and I can't even replace them because of this. How do you remove them from the strut if it just keeps spinning, I have the special tool and can see that the inner threaded part is not rotating when I turn the nut. I guess this must be the cause of my clunking anyway. What's the best way to remove all of this? I probably need new shocks if it won't spin off.
      • audiquattrot
        • May 2008
        • 3836
        I had a slight clunk and figured out when I initially installed the front struts into the housing, they were ever so threaded loosely. I lifted up the strut accordion boot and took a big monkey wrench to the top of the strut.....and gave it 1-2 turns until tight....and it solved my issue.
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
        • rwtags
          • Aug 2018
          • 208
          After strut mount and new shocks the clunk seems to be gone. There was a lot of play in the old strut tower bearings, and lots of metal particles in their grease. New ones were needed, those might have been the original. Glad I fixed that.
