Who has a turbo IX? Turbo setup? (Turbo, injectors, fuel pump,) How much HP? Stock drive train reliability? Sent from my SM-G973U using Tapatalk
Turbo Ix Roll Call
Tags: None
Currently swapping all my turbo parts into my other iX right now because I got into and accident unfortunately.
HX35 turbo, internal wastegate welded shut.
DIYPSI top mount turbo manifold (http://www.diypsi.net/product/bmw-e3...urbo-manifold/)
Note: If you buy this manifold, expect to have a machine shop deck the flange surface. It will be warped. My buddy and I both bought one and they were both warped in the middle. The seller did refund the cost of machining.
30lb orange bosch injectors from a Volvo B5254T engine
Tial MVR 44mm wastegate
Tial Q BOV
2.5" charge pipes made from a CX racing universal kit
3" exhaust made from mandrel bend mild steel
dynaflow muffler + resonator
GM wasted spark
DIYPNP MS2
Stock fuel pump
Stock clutch
MAC valve @ 10PSI
ARP headbolts + stock gasket (installed with head on, 1 at a time)
HP: No idea, never dyno'd. Somewhere between 250-300 on the butt dyno.
Reliability: Drove it daily summer and winter for 3 years with zero problems until I got into an accident. -
Still have mine, probably going on 5 years of being boosted, 3 of which was all stock drivetrain https://youtu.be/RcnuHVD1QFs Sent from my SM-G892A using TapatalkComment
Your setup is amazing bud. It's been an inspiration for mine.Still have mine, probably going on 5 years of being boosted, 3 of which was all stock drivetrain https://youtu.be/RcnuHVD1QFs Sent from my SM-G892A using TapatalkComment
How much power were you making on the stock drive train? What setup are you running now? I see a Dct. What is the front diff setup? Since I hear they are the weak link. Sent from my SM-G973U using TapatalkStill have mine, probably going on 5 years of being boosted, 3 of which was all stock drivetrain https://youtu.be/RcnuHVD1QFs Sent from my SM-G892A using TapatalkComment
Nice setup! I have my second build going after the tuner I used destroyed my first engine. I'm just curious as to how much power I can run and not have to stockpile front diffs. Sent from my SM-G973U using TapatalkCurrently swapping all my turbo parts into my other iX right now because I got into and accident unfortunately. HX35 turbo, internal wastegate welded shut. DIYPSI top mount turbo manifold (http://www.diypsi.net/product/bmw-e3...urbo-manifold/) Note: If you buy this manifold, expect to have a machine shop deck the flange surface. It will be warped. My buddy and I both bought one and they were both warped in the middle. The seller did refund the cost of machining. 30lb orange bosch injectors from a Volvo B5254T engine Tial MVR 44mm wastegate Tial Q BOV 2.5" charge pipes made from a CX racing universal kit 3" exhaust made from mandrel bend mild steel dynaflow muffler + resonator GM wasted spark DIYPNP MS2 Stock fuel pump Stock clutch MAC valve @ 10PSI ARP headbolts + stock gasket (installed with head on, 1 at a time) HP: No idea, never dyno'd. Somewhere between 250-300 on the butt dyno. Reliability: Drove it daily summer and winter for 3 years with zero problems until I got into an accident.Comment
I honestly think he just flat out didn't know what the fuck he was doing. It was detonating so bad it broke all the compression rings and destroyed the pistons. Also left melted piston material on the cylinder walls.
I'm using the exact same as you MSPNP2. Is your engine a 2.5? I'm building a stroker 2.8 with a m52b28 cranks 135mm forged pistons and Custom forged CP pistons. Sent from my SM-G973U using TapatalkComment
I wanted to run a different cam. I was planning on running a bimmerheads billet or regrind but they are both sold out. A 280/274 is what I want to get. Do you have a different cam in yours? I also have a snow performance water/meth kit as e85 isn't available where I live. Sent from my SM-G973U using TapatalkComment
From what I've read the stock cam is pretty good for boost. I'm still on the fence whether I should change my cam or not. Depends on the setup really both provide higher octane for more boost and more aggressive timing. The water in the water/meth also cools the intake charge so it has that advantage as well. Sent from my SM-G973U using TapatalkComment
I ran it about 400-450 wheel on the stock front diff. Did a good bit of launches on it also. Now I'm running a e34 front diff and axles Sent from my SM-G892A using TapatalkComment
