Originally posted by nomansland92
View Post
Turbo Ix Roll Call
Originally posted by CrazyPrime View PostThat sounds promising then Still an m20? Or 24v swap? Sent from my SM-G973U using Tapatalk
Originally posted by CrazyPrime View PostWhat did you end up doing to mount the e34 stuff? Sent from my SM-G973U using TapatalkSent from my SM-G892A using Tapatalk
- Likes 1
Originally posted by nomansland92 View PostTakes a bit of weldingSent from my SM-G892A using Tapatalk
Originally posted by CrazyPrime View PostSo you basically just took a e34 pan diff area and cut and welded it to a e30 pan. I've thought about doing that. What did you do for axles and the front drive shaft? Sent from my SM-G973U using Tapatalk
Originally posted by nomansland92 View PostYep pretty much. Its gets kinda complex thought because the e34 sits a 30 degrees and the m20 sits at 20degrees. Axles just need a little machining on a lathe near the abs ring to fit. The stock front driveshaft shaft will actually end up deeper into the tcase for better spline engagement. But you will need to lathe off and move the oring groove at the tcase to the new correct spot. I use billit splines and had the whole shaft lengthened because of the dct. Sent from my SM-G892A using Tapatalk
Kershaw, I think your pics are broken. I drilled the block on both of my cars. I drilled and tapped right behind where the AC compressor bracket was on my last one. I drilled farther back on my most recent build because I retained AC this time. Here’s a pic of the pilot hole. And yes, I did do this with the engine installed and oil pan on. I greased up the drill bit and tap to catch most of the shavings. Then I flush the hole out with about 2 gallons of the cheapest oil I can find.Sent from my iPhone using Tapatalk
Originally posted by nomansland92 View PostI ran it in oil pan for a few years but ended up moving it higher up into the block so it sat above oil level.Sent from my SM-G892A using Tapatalk
Originally posted by CrazyPrime View PostWhat was the benefit of moving it up? If it worked for years? I know some people run the turbo drain on the oil drain plug on cars like hondas and other ones. Sent from my SM-G973U using Tapatalk
