Seen it done. Have used it myself. Personally hate the texture. More useful for insulation & sound deadening.
					Blitz Black Turbo E30 (old thread was about Plasti-dip)
I don't like the flatness of the plasti dip so my final coat I put on dry to get a textured look. Here's my A's done until I have cash to properly powder coat them
There still a bit wet and the flash washed out the black a bit
Sent from my Galaxy Nexus using Tapatalk 2Comment
I'm dipping my car because I want to do something different, I have a booth that I paint out of and have paint. I would rather dip my car now so I can focus on putting my turbo and megasquirt in. When that's all done and I feel like it I will really spray it. I'm doing it one day this week, I'll post pics of the after math!
Any updates on this? Can you post up some pics of he finished product?
Thankssigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback ThreadComment
I used plasidip on my front grills. It holds up great, been through many washes with no fading. I cleaned all my grills with simple green then rinsed in a 90/10 mix of water/alchohol. That alone cleaned them up nicely, then I got the little spray adapter for the can and sprayed 5-6 thin coats and made sure to wipe it clean between coats as it can clog up. Shake the hell out off that stuff before you start and while you wait between coats. There is a technique to getting good coverage and you definitely need to let each coat partially cure for at least 15 minutes before applying the next. If your doing a whole car, I think the pro kit is the only way to go https://www.dipyourcar.com/home.php?cat=15 so you can apply thin even coats over a larger surface area vs. the spray can. There is a little texture but if you can master the art of dusting the coats I think the finish will be much smoother.
Great for trim pieces, not completely sold on doing a whole car. But it's cheap and it's non-destructive for the most part.
Also if applied correctly to the right surface it will not simply rub off. For a car, I would suggest making sure there is no wax on it.Last edited by djmossm42; 12-06-2012, 04:08 AM.Comment
I know a guy who did his Sky. Turned out pretty damn good for 200 bucks.
Looked good enough his friends did it too...
						What it feels like owning an e30:
88 325 S50 swap in progress
90 325ix
Like yeah - you could do the whole car..
but I would hold off on doing the windows..Comment
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
 DREWLIENTE
