How much to fix cracked frame?
  • sedrat
    • Jun 2019
    • 18
    I have a 318is and the frame is cracked in two places in the front right. I think that the frame was initially tweaked a bit and finally failed when I redid the suspension with stiffer parts. There are some pics attached.
    Any idea how much this will be to repair? Is it even worth saving? Also, if anyone has any good body shop reccomdations in the Sacramento area, that would be rad.
  • efficient
    • Feb 2012
    • 3312
    i had this problem. what i did was i took the paint off and had some dude weld it for me. you most likely have cracks closer to the firewall where the ac pipes go into. the one i didn't have is the lower one on the shock mount. to answer your question i paid 20 for the welder to weld it for me.
    • Mpolito3355
      • Mar 2018
      • 82
      Not your frame, the thing that's cracked is your seam sealer from the factory it just gets old and rots away in places. A auto body place can re seam seal it and paint it but I'd wait for a engine bay respray and have the whole thing seam sealed and painted.
      PERSON 1 - "It whispers to me at night...and convinces me i have to spend all my earnings on it...and buy all this stuff....to be cool...and be euro."
      PERSON 2 - "Oh your married too?? Oh you mean the car....yes ....yes i agree...:shock:"
      • moatilliatta
        • 6157
        Look In the inner fender around fire wall to frame, it’s not uncommon for these to pull away.
        It’s most likely more than just cracked seam sealer.
        @Zakspeed_US
        • E30SPDFRK
          • 5715
          Seam sealer cracks because the metal under it opens up. Those are totally cracks, and that is a very common area to crack after you install stiffer suspension.
          The price will vary based on how well done you would like the repair to be. $20 would get it welded, or $2000+ could go to stripping back all the material, welding it, resealing and repainting the area.
          Byron
          Leichtbau
          • sedrat
            • Jun 2019
            • 18
            Yeah, it's definitely a metal crack. I shined a light in there and you could see that the metal was separated.
