Problem installing drivers seat
  • APmovement
    • Nov 2012
    • 50
    So I just bought the black leather sports seats for my car, problem is that the drivers side seems like its busted. When I pull the knob for it to pull up it doesn't work. I need the seat to be able to move up for me to screw in the back two screws. Any thoughts or solutions? Thanks in advance.
    My first guess is that the gas "springs" in the seat are shot. Lift up on the seat while operating the control.
    • reelizmpro
      • 9558
      The slider mechanism is easy to figure out. Have a look under the seat and see why both sides aren't disengaging. Maybe the rod is missing or bent.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • jeffnhiscars
        • Jun 2011
        • 6011
        If its a coupe seat tilt it forward with the release lever on the side of the seat back. If its a sedan seat lift the seat back adjustment handle and lean the seat as far forward as it will go. The 2 screws should be accessible.
        If you are talking about bolting the seat down to the floor ignore this. The only "2 screws" are to hold the vinyl seat back to the frame which are the ones I was referring to
        Alice the Time Capsule
        • nugentnsb
          • Jul 2011
          • 444
          • APmovement
            • Nov 2012
            • 50
            I figured out the problem. The wire to lift the seats on the right side had been cut. I was able to find away around it. Thanks a lot for all the help guys!
