What do I need to install this M-Tech II Steering Wheel?
  • Prost
    • Nov 2012
    • 193
    I just got this M-Tech II steering wheel, what do I need extra to install it to my E30?
    Also, anyone know where to "retrim" the leather in SoCal?
    92 Alpine White 325iC M-Tech II Appearance Package
  • Dj Buttchug
    • Jun 2010
    • 7686
    if im not mistaken that will bolt right on to an airbag steering column
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • reelizmpro
      • 9556
      E36 steering column. Looks like an e36 wheel...won't work without major mods. Sorry.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        should bolt right up.
        fine spline and everything.
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          you need a 22mm socket on an extension, and your keys.
          put your keys in the ignition, pop the BMW emblem off your old wheel to access the 22mm nut, undo the nut, slide the wheel off (this can be difficult be careful dont slam the wheel into your dome.) and then install the new wheel, straight.
          • Dj Buttchug
            • Jun 2010
            • 7686
            it depends on the size diameter of the spline hole. if its off an e36 then no, it wont work as stated above.
            Edit: must be e36 wheel cause of thumb cutouts
            Ig:ryno_pzk
            • noid
              • 1537
              Those are E36 splines and that wheel will only fit e36/e34's. It will NOT fit an E30 in anyway.
              Sorry to inform you man. Yes I am certain.
              Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
              Your resource to tools and tips: www.rtstools.com
              • bimmer2288
                • Feb 2006
                • 273
                Maybe you could weld it on .......
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Part number shows it coming from an e31.
                  http://www.realoem.com/bmw/partxref.do?part=1159065
                  • rav320uk
                    • Jun 2004
                    • 1337
                    An E36. if it's an E36 wheel.
                    :D
                    If you have bought items from me, please leave feedback below.
                    If you are a BUYER, Check My Feedback.:up:
                    http://www.r3vlimited.com/board/showthread.php?t=183860
                    Check out my Euro Build Thread
                    http://www.r3vlimited.com/board/showthread.php?t=215557
                    • Prost
                      • Nov 2012
                      • 193
                      So from all the post, this is an E36 wheel and not have a chance to fit my E30?
                      Any picture of an "E30" M-Tech II wheel that I can compare?
                      • smerfs
                        • 319
                        if you're wondering if it fits, why not just try to bolt it on...You just need 1 bolt and a marker to put on a steering wheel
                        320I - under construction
                        • reelizmpro
                          • 9556
                          Looks like an E36 but as mentioned the PN shows E31 8 series. Either way, it won't fit. The backside is different.
                          Here's the back of an E30 wheel...
                          As you can see, they are very different. It's not uncommon to have people abroad (like on ebay) sell other M tech 2 wheels as E30/E28 but they won't fit. Several members have gone through the same thing as you. This is why you have to do your homework and make sure you get the right parts.
                          88 M3 - LACHSSILBER
                          • Prost
                            • Nov 2012
                            • 193
                            Thanks
                            • Prost
                              • Nov 2012
                              • 193
                              I will try it tonight or tomorrow...the seller told me that he took it out from an E30 :curse: I will demand a refund if that is not the case...
