Rattlecan fabric paint on my e30's carpet, will it work?
  • jimsill
    • Nov 2005
    • 548
    I used duplicolor fabric paint on my 2002 carpet and although it looked great, it wore like shit due to the polyester nature of the carpet (rubs off at normal friction pints like door sills and tranny tunnel sides)
    Trying to go from natur to black, anyone have any success with this?
    both these cars are gone :(
  • Steven
    • Dec 2012
    • 2305
    I did it... Just get matts and it'll last. It's not a big deal to touch it up after a while anyways.
    Feedback!
    Custom Cup Holder Consoles!
    Calypso Story--S50/Shaved and Tucked Bay
    • jhaurimn
      • Nov 2012
      • 2224
      I've heard good things about VHT (?) vinyl and fabric dye....
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • Mr. Tasty
        • Jul 2011
        • 3421
        I would use RIT dye in a spray bottle
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • jrobie79
          • Mar 2006
          • 2525
          colorbond by bryndana...shit is the tits
          http://www.colorbondpaint.com/
          1991 318i ---- 308K - retired
          • monty23psk
            • Mar 2008
            • 1289
            ^ highly recommended. Did mine, almost 3 years ago with the same color with no fading to this date. I did have to touch up a few places as the did not place enough paint. Key is light coats and rub it in with a sock once it is almost try to spread it into fibers. my project thread has some pics.
            Alex 88 m5 | 91 318is | 19 Subaru Ascent
            BMW Tool Rentals & Fender Roller
            • StereoInstaller1
              GAS
              • 22679
              Wow...that colorbond is $15 a fucking can...I used 4 cans of VHT on mine, it is holding up well BTW. However, storage generally is not too tough on carpets.
              Closing SOON!
              Thanks for 10 years of fun!
              • BMWManiac
                • Dec 2010
                • 1091
                Plus, its a car carpet....you rarely will ever touch it except to vacuum it....not like you'll be laying down on it. I used the VHT die and it came out great
                1997 Artic Silver M3
                CES GT4094r 651hp/615tq @ 24 psi
                • LivingLegend06
                  • Dec 2006
                  • 1604
                  I used VHT on my sun faded rear shelf and it came out pretty good. Its only been 6 months but I cant see any fading yet.
                  I also used it to dye some tan door panels black, it worked well and is a pretty good match to the factory black door panels.
                  • Jand3rson
                    • 37587
                    I did my tan carpet to black a few years ago, came out really good. I did one coat, then brushed it out with a stiff brush in all directions to expose any areas that didn't get coated, and then did it again, then brushed it out one more time.
                    • Cletonius
                      • 2809
                      I've used sem color coat to do it, spray, brush, spray, brush. It'll last about a decade from what I've been told.
                      - Josh
                      1990 325is
                      Need a shift boot?
                      Looking to buy shift boot frames, PM if you have one to sell
                      Here's what happens when you let the internet pick your license plate
                      • TheTenor
                        • Feb 2014
                        • 70
                        I started to dye my tan convertible carpet with Duplicolor. I was semi pleased as I wasn't able to get the color down to the bottom of the nap well. I'm going to try to go back over it with either RIT or Dylon dye to see which does the best. Either that or I have found a carpet kit that is cut from the OEM pattern, but it is $499 :-/
                        • Cletonius
                          • 2809
                          I can get molded coupe carpet for less than that... Shoot me a PM if interested.
                          - Josh
                          1990 325is
                          Need a shift boot?
