How to remove e30 steering wheel without ignition key?
  • Mr. Burns
    • Aug 2011
    • 3516
    It's in a pnp.
    Flathead screwdriver+hammer and bash?
    I'd much rather not be so barbaric...
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • LJ851
    • 7918
    Originally posted by Mr. Burns
    It's in a pnp.
    It is a barbaric task, there will be some carnage.
    Lorin
    The M30 is God's engine.
    • Swanny
      • Mar 2012
      • 2834
      Get with it.
      Would also recommend something with a hex or squared shaft that you could get a crescent or adjustable wrench on to get better leverage to pop the cylinder once you bang it in there.
      Vids of barbaric task are appreciated
      Swanny!
      SUCKERS.
      • DER E30
        • Sep 2013
        • 2347
        I'm confused. My steering wheel came right off with one nut behind the emblem... Of course I just moved it over a notch and put it back together... How should it be barbaric?
        -Christian
        • matthugie
          • Mar 2004
          • 1810
          The car is at a junkyard, OP has no key to release the wheel. Yours shouldn't have just come off without the key in the ignition.
          88 325is - S52 powered
          Originally posted by King Arthur
          We'll not risk another frontal assault, that rabbit's dynamite!
          • DER E30
            • Sep 2013
            • 2347
            Weird... I had the key in it for the beginning, then pulled the key to use the locking plate thing to keep the steering from going anywhere while I re-centered it. Maybe its just another thing that's half broken on my car Wouldn't be the first time
            -Christian
            • Chessmaster
              • Jun 2012
              • 501
              Get a trunk lock, go to shady place in town and get a key made for cheap. Is it late or early model, you can prob just saw zall the steering column then just unbolt it.
              • Swanny
                • Mar 2012
                • 2834
                Why do that much?
                Swanny!
                SUCKERS.
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  Originally posted by Swanny
                  Get with it.
                  This will be executed later this week.
                  Standby.
                  • glnr13
                    • 1334
                    nah man, hack saw the aluminum lock that holds the wheel in. comes out in 5-10 mins of sawing.
                    i read this and followed it to a T and got an mtech1 out of the junks:
                    the first time i tried to barbarian that thing out I bent the top of the wheel and nicked couple of the splines, wasn't happy.
                    • Sea Aych
                      • Apr 2013
                      • 763
                      Try putting your e30s key in the junkyard car's iginition...It may surprise you depending on how old and worn out the cylinder is. I've had it work twice!
                      Otherwise yeah take the trunk lock or the door one to a shady locksmith
                      1988 Atlantisblau Euro/Japanese 325i Cabriolet
                      1989 Schwartz 325i - now M50 powered! - now very dead
                      1998 Toyota 4Runner Limited
                      My 17,000km Big NA National Parks trip!
                      • Milehigh30
                        • Mar 2013
                        • 79
                        what sea aych said. i found a mtech 1 but no key. another guy found another mtech1 in same yard and they car had the key. so i grabbed the keys and fiddled with the key and it worked. so i saved the key for future tries. i stopped at a different yard 2 days later and found a almost perfect mtech1 and grabbed the keys and sure enough it worked again!
                        • AwakenNoMore
                          • Dec 2010
                          • 1291
                          Just hacksaw right behind the wheel between the wheel and the plastic column cover, you will know when its free when you can turn the wheel.
                          1991 325i - "Scambles" The Daily Driven lightly modded.
                          1988 Mazda RX-7 TII "Mako" The Free Dorito
                          bacon by Jared Laabs, on Flickr
                          • Thizzelle
                            • 4422
                            I've unbolted the 22mm then just shook it back and forth until metal in back bent out enough for wheel to come off. then just hammer it back flat.
                            "I wanna see da boat movie"
                            "I got a tree on my house"
                            • g.ruff561
                              • 1261
                              ^^^^^^ did that not ruin the spline?
