need help with my M Tech 1 steering wheel installment!!
  • Erkan
    • Apr 2014
    • 57
    Okau so my friend said once I took out the air bag steering off, all I would need is another spacer. Car came with one so I added another spacer to it. When I add the steering wheel and washer and bolt, it doesn't reach the lock and the horn button. I tried 1 spacer and then the steering wheel but then I can't turn the steering wheel all the way. Do I need a 2nd spacer but smaller from the OEM spacer?? If so will home depot may have it? I have a 1990 325i. Thanks!!
  • reelizmpro
    • 9558
    Yes. I used washers stacked on each other.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Erkan
      • Apr 2014
      • 57
      Wait you took out both spacer and added washers or 1 spacer and 1 or 2 or 3 washers?
      • audiquattrot
        • May 2008
        • 3836
        you're supposed to put the spacer on after installing the wheel, then the nut over that.....not the spacer first.
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
        • Erkan
          • Apr 2014
          • 57
          Okay so I basically did what your said and now I can't turn the wheel all the way... I put the steering wheel without any spacer so put the wheel and then I put 1 spacer and washer and bolt. It locks and horn works but won't turn all the way, as if it's hitting something
          • Todd Black 88
            • Oct 2007
            • 3449
            Did you remove the white plastic pin in the steering colum?
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • jdt10768
              • Feb 2013
              • 484
              st column must be unlocked and straight before you start the process
              • Erkan
                • Apr 2014
                • 57
                No I didn't I see it. How do I take it out?
                • Erkan
                  • Apr 2014
                  • 57
                  What you mean? Sorry I just got lost and confused about the swap. It was simply on my 87 325e but now on this late model.. wth..
                  • JIM1inWisconsin
                    • Dec 2014
                    • 116
                    wheel
                    As I recall the white pin pulls out or comes out very easily but it must be removed. The white pin is seen when the steering wheel is removed in the upper left on the face of the column. Order of arrangement on my car is.... 1-spacer 2-wheel 3-spacer 4-washer 5-nut.
                    Horn works and wheel turns.
                    You will find the directional stalks to be a bit closer to the wheel but it's not a big deal.
