I pulled my seats today to clean the mess that is my newly acquired car's interior and found this under the rear seat. I've looked through diagrams of the fuel system, but can't quite determine what it is. Would love it if someone could school me on it!
What is this rusted business under my rear seat?
Zelig the Zinno • 300k and counting
http://instagram.com/zelig.the.zinnoTags: None -
Nevermind, discovered it's the vent tube.Last edited by Shu; 11-13-2015, 12:04 PM.Zelig the Zinno • 300k and counting
http://instagram.com/zelig.the.zinno -
shitRenting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Just found this same problem on my car (1988 Touring - damn German salt). It looks like the actual rubber and plastic vent tubes run through this metal tube. Is that correct? If I seal up the hole in the wheel well, is it a problem to just leave this tube as is?
Has anyone replaced the rubber and plastic vent hoses? Is it tough to get them out through this metal tube? I'm guessing that the tank would need to be dropped, correct?
Thanks. Any advice is much appreciated.
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
http://instagram.com/zelig.the.zinnoComment
Mud gets inside there and keeps in the moisture and causes eventual rust. Ask people who have changed their gas tanks...The rubber hose starts to degrade and makes it fun to pull a new one through that mess. Also included is that cover inside the passengers side wheel well.Comment
Thank you for the responses! I should have access to a lift by early spring, so hopefully I can wait until then to drop the tank and replace these lines.1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
BMWCCA
E30CCAComment
Cory
If you remove the top section of the plastic fender liner that will give you access to the expansion tank and I think most of the hoses for inspection and/or replacement. There's also a tab that supports the expansion tank and mine was gone so the tank is just resting on the plastic liner. I forgot until now so clearly not a problemSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
