Lseat.com Leather Seat Covers???
  • mbonanni
    • Sep 2011
    • 6236
    #106
    Unfortunately I have taken both seats apart, but know what bar you’re talking about and know how everything went together. I tried to get the hog rings on there but absolutely could not, which I believe is because my hog ring pliers are really bad, do NOT get harbor freight ones for this job. I may just staple these flaps down, we’ll see.
    I was following a video posted earlier in the thread and he uses fabric adhesive to fold the edges in around the center foam pieces, but the stapler will probably work better for all my problems, I’ll look into one of those.
    In the video the guy also uses hog rings and not string to secure the leather to the divots. The string idea is much better, and that’s what was used from factory it appears. I’ll give that a go today, thanks for all the help.
    • Mike36
      • 1079
      #107
      Originally posted by DJNikonn
      How did you do the door panels?
      I had an extra pair of door panels and just ordered more material from Lseat. I took the front panels to a shop, they actually did a good job matching the OEM faux stitching that goes across the door panels. I went ahead and did the rear panels, I was even able to perfectly match the OEM speaker holes.
      Originally posted by mbonanni
      I am actually not done with the upper bolster lower outside corners, what did everyone do to anchor these down? My hog ring pliers don't seem to fit in the frame at the right angle. I can tuck the flaps and it looks pretty good so I am thinking I'll just use some spry fabric adhesive to keep these down, but curious how these corners were for everyone else.
      If I recall correctly, there should be small hooks on those corners or I believe you're suppose to pull them through and hog ring them to the seat frame. I'll try and check this weekend.
      • mbonanni
        • Sep 2011
        • 6236
        #108
        Well I ran to Harbor Freight to get a crown stapler to get there and realize it’s pneumatic, and I don’t heave air. Bought a regular t50 stapler, doesn’t work because the staples just pull right out of the foam. Figured I go to Home Depot to get a better set of hog ring pliers and tried those, doesn’t work for the centers but might for the flaps. May just have to take the centers to an upholstery shop to do them properly.
        • Pootis
          • 636
          #109
          Yeah you have to use a stapler with air. You have to know someone with an air compressor or just buy a pancake one from harbor freight
          1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
          COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
          • efficient
            • Feb 2012
            • 3312
            #110
            Originally posted by MSGGrunt
            The best YouTube video I found was this one which is E30 sport seat specific.
            https://www.youtube.com/watch?v=bUuhdw4ZEcY
            you guys seen this video? might be of help
            • Mike36
              • 1079
              #111
              Yeah that video was what got me through my install. I actually did what he did and used hog rings instead of staples for the seat bottoms. Had I known about a crown stapler, I would’ve gone that route since that’s how OEM is done. Either way, the hog rings into the seats foam worked fine for me.
              • mbonanni
                • Sep 2011
                • 6236
                #112
                That’s the video I’ve been referring to in my recent posts, and why I was going to get some fabric adhesive. For those of you who used adhesive, did it help keep the edges down while you staples/hog ringed? Perhaps I’m just being too gentle with the foam/hog rings? To me it seems as if there are upholstery specific hog ring pliers because both of the ones I have engage the ring 1/2” or more into the pliers and I just cannot manage to get them deep enough so the ring can go through both the foam and leather.
                • Mike36
                  • 1079
                  #113
                  Are you using one of these?
                  https://www.amazon.com/Pliers-Galvan...-2-spons&psc=1
                  • mbonanni
                    • Sep 2011
                    • 6236
                    #114
                    Nope, didn’t want to wait for shipping at the time so I got some from Harbor Freight automotive section and then some from Home Depot. I assume the ones I got are more general purpose, and will return both today and order some of the ones you posted. Looking at the design I’m guessing the ring will be in a much more accessible position to anchor stuff down.
                    • Mike36
                      • 1079
                      #115
                      Oh yeah, world of a difference with actual hog ring pliers. Should make your job much easier.
                      • mbonanni
                        • Sep 2011
                        • 6236
                        #116
                        Been neglecting posting photos because i still need a couple things to finish the interior, but the front seats are done with the exception of the seat shocks. I am having trouble with the passenger side tilt locking. It won't lock in any position other than furthest forward. I am happy how they turned out though, sorry for the crappy iphone pics.
                        • Mike36
                          • 1079
                          #117
                          Thats hot! Be ready for all the compliments you'll be getting about your interior, it never gets old. Haha. For some reason, lots of e30 owners seem to neglect their interior. Congrats.
                          Make sure the passenger tilt handle is pressed all the way down so that the seat locks in place.
                          • Tzantushka
                            • Nov 2018
                            • 390
                            #118
                            They look great - I see you went for the piping on the bolster ridges.
                            (instead of the french seam)
                            With the tilt mechanism, I had a similar issue with mine.
                            While I was replacing the seat shocks and cable, I sprayed some brake cleaner down the ratcheting mechanism to clear out the old grease, fluff, and debris that was causing the spring to bind.
                            Make sure you protect the leather with some plastic or cloth from the run-off.
                            In the end I didn't go down the path of recovering.
                            With some hours cleaning, conditioning and fixing the broken parts the seats are back to new. Painted seat rails and a new seat belt buckle make it worth it.
                            Even the cat approves.
                            E30 320i vert
                            But daily drive is Volvo V60 Polestar
                            • mbonanni
                              • Sep 2011
                              • 6236
                              #119
                              Thanks Mike! Yeah this is the first e30 I will own that will have a solid interior and I’m very excited for it. I think I am going to remove the headrests and cover then with a layer of foam because they are a big baggy to the touch.
                              I actually opted for no piping when ordering but they went ahead and did it anyways. I would have much preferred them with out it. If I didn’t have rips I would have just cleaned mine up, yours turned out very good.
                              • Mike36
                                • 1079
                                #120
                                Did you steam any of the seat foam/headrest? It was night and day after i steamed all my foam, everything was nice and snug except for my rear seat back that needed extra padding.
