Have you checked your high beam fuse
Brights?
alright, further inspection shows that fuses 1,2,13,14 are fine. They are sealed beamsLast edited by GunMetalGrey; 12-23-2010, 05:11 PM.
Originally posted by bmwm42 View PostRelay
Originally posted by blackhawkimpact View PostProbably OP tried to "jump the relay to keep your low beams on with the high beams" mod and did it wrong?
If you're really cheap. Just pull out the working lights on the drivers side and plug into the pass side to see if they work. Then when they do, go out and buy new lights.
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hp
Hey there friend, I see youre completely ignoring nando. not ususally a good plan as hes a pretty smart guy.
Heres what you need to do, with that relay that you think is wrong in place, get a multi meter and unhook your suspect low beam. There should be 3 wires here if im not mistaken, turn on your low beams and measure the voltage of the wires, one of them should read 12V, the other 2 should read 0. Now turn on your highbeams and measure the remaining 2 wires, one of them should read 12V if the system is functioning properly.
If you find that with the high beams on one of the wires reads 12V, get a new lowbeam cause its burnt out.
If you find you still get 0 reading, get a new relay and try again.
and lastly i think your high beam on that side is just plain burnt out, you could check by using the one from the other side that you know works.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.
