Brights?
  • DaveSmed
    • Apr 2007
    • 1407
    #61
    Originally posted by GunMetalGrey
    ok, to make it short and simple, fuse 2 is dead, when i would test it with brights with the multi meter it would read nothing. When i moved the negative lead to the engine block it gave 12 volts. So a broken wire it is?
    Yessir, assuming the lights were plugged in at the time.
    Now you have an absolute diagnosis, the White/Blue wire has a break. Not "well maybe its this, buy one and see if it fixes it" bullshit.
    First order of business, any evidence of collision damage? If not, check and make sure that there are two White/blue wires attached to the inner light's terminal (one jumps over to the outer light) If the feed broke off leaving only the jumper attached, that would cause the problem.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • GunMetalGrey
      • Dec 2010
      • 1499
      #62
      ok, I think i found the problem! but how do you take out the inner contacts from the female part of the headlight plug? http://www.partsgeek.com/gbproducts/...ek+Google+Base just so you know what I mean
      • DaveSmed
        • Apr 2007
        • 1407
        #63
        First off, don't double post. Especially around here. It's not tolerated very well.
        Second, take a look at this pic.
        Note how in the center of the back of the terminal, there's a tang sticking out? You have to push that tang in, and then LIGHTLY tug on the wire. It takes some finesse, and since you haven't done it before it might take a couple tries, esp. without the right tool. But when you get it, the wire should easily slide right out.
        -Dave
        • GunMetalGrey
          • Dec 2010
          • 1499
          #64
          Triumph! I have solved the problem! The blue/white wire going into the inner light was totally eroded on the plug, rusted out, so no current was getting to that bulb, and since it piggy backs to the other side it wouldnt give that side power, cut down the wires a bit and soldered them on. And it works perfectly
          • accident
            • 7303
            #65
            it's the bulb.
            Moral of this story?
            • GunMetalGrey
              • Dec 2010
              • 1499
              #66
              Originally posted by accident
              it's the bulb.
              Nope, it was the wires going to the plug for the bulb.
              • accident
                • 7303
                #67
                replace your bulb.
                • DaveSmed
                  • Apr 2007
                  • 1407
                  #68
                  its always the bulb
                  -Dave
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    #69
                    Originally posted by DaveSmed
                    its always the bulb
                    Are you kidding or being serious?
                    • accident
                      • 7303
                      #70
                      change the bulb!
                      • bmwm42
                        • 6300
                        #71
                        Wow
                        Originally posted by bmwm42
                        PNW vulture pm me for parts
                        Strategic nw e30 command
                        • alanhoppe
                          • Dec 2010
                          • 2
                          #72
                          Good Job kid! Persistance pays off. This has been an enlightening thread. There have been a lot of good ideas and theories to help you along. The bulb being out would stand to reason and you tried that, to no avail. From there the relay and fuse all checking out. Tackling a short can be a very daunting task and it looks like you got'er! Let us know how the rest of the car is and what you're going to do with it- being a first car and all.
                          • sweet88
                            • Feb 2011
                            • 64
                            #73
                            for the love of fuck, buy new lights.
                            I just love that!
                            Our Lady of Blessed Acceleration, don't fail me now.
