Brights?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Brights?
    I was wondering if when you guys turn you brights on, (the inner top lights) If the outers go out, so it is just the high beams, and not the lows.
    • 34847
    they aren't supposed to
    do you have sealed beams? if so, the high beam fillament is probably burned out.
    • GunMetalGrey
      • Dec 2010
      • 1499
      No i was just wondering. The last guy that had the car must have messed up the wiring, because when I turn on my brights the left bright and lowbeam go on, but the right side goes all dark, Wiring Time!
        • 34847
        that's why I asked
        DO YOU HAVE SEALED BEAMS
        it's likely you just have a burned out bulb. ;)
        • GunMetalGrey
          • Dec 2010
          • 1499
          well the odd thing is that the right side lowbeam works fine without the brights on, if i turn the brights on it goes out... I dont know if they are sealed beams, not to familiar with headlights yet, yeah the bulb is what I was going to check tonight.
            • 34847
            I know. that's because sealed beams have 2 filaments on the low beam bulbs - it actually has both a high beam and a low beam. if it goes out when you turn on the brights, that means the high beam filament on that light is burned out.
            • GunMetalGrey
              • Dec 2010
              • 1499
              I will get a diagram later, I have 4 headlights in total, the outers appear to be lowbeams, and the inners appear to be the highs, the outers are only on with the driving lights, the inners ONLY go on when I hit push/pull the lever for the highbeams.
                • 34847
                they are low/high beams built into one light.
                91 318is?
                they are sealed beams. the bulb is burned out.
                • M-technik-3
                  • 18946
                  Buy a new headlight, After you install it you can thank us. It's called a dual filament.
                  And if you doubt us take out your multimeter and check for voltage when it on or swap low beams.
                  • bmwm42
                    • 6300
                    if the low beams come on but when you turn on your highs and one side goes dead its ur freaking fuse
                    Originally posted by bmwm42
                    PNW vulture pm me for parts
                    Strategic nw e30 command
                      • 34847
                      fuck
                      no it isn't. sealed beam low's have TWO filaments.
                      the high beam filament is simply burned out.
                      /thread
                      • bmwm42
                        • 6300
                        you are correct that the low beams have a dual filament bulb but if the fuse is out for the highs it will kill the power to the whole side go to your car put in a bad fuse in the high beam section and tell me what happens
                          • 34847
                          there isn't a left and right side fuse for headlights. lol
                          • bmwm42
                            • 6300
                            Fuse No. Amp Description
                            1 7.5 Headlight, left high beam
                            2 7.5 Headlight, right high beam
                            3 15 Aux. cooling fan, low speed
                            4 15 Turn signals
                            emergency flasher
                            Active Check control
                            Digital Clock
                            5 30 Windshield wiper and washer
                            6 7.5 Stop lights
                            Cruise control
                            Active check control
                            ABS
                            Interior lights
                            7 15 Horn
                            8 30 Rear defogger
                            9 15 Fuel delivery
                            Idle speed
                            10 7.5 Seat belt warning system
                            Service interval indicator
                            Tachometer/fuel economy gauge
                            Instrument gauges and indicators
                            Brake warning system
                            Back-up lights
                            OBC
                            Starter
                            Fuel delivery
                            Idle speed
                            Stop lights and cruise control
                            11 7.5 Fuel pump
                            12 7.5 Radio power
                            Speedometer/instrument indicators
                            OBC
                            Multifunction Clock
                            13 7.5 Left Low Beam
                            14 7.5 Right Low Beam
                            15 BLANK
                            16 15 Heated Seats
                            17 30 Sunroof
                            Power Windows
                            18 30 Aux. cooling fan, high speed
                            19 7.5 Aux. cooling fan
                            Interior lights
                            Power mirrors
                            20 30 20 30 Heater/Air conditioner
                            Auxiliary Radiator cooling fan
                            21 7.5 Glovebox light
                            Flashlight
                            Ignition Key/Seat Belt warning
                            Interior Lights
                            Radio Memory
                            Trunk Light
                            Active Check Control
                            Service Interval Indicator
                            OBC
                            Fuel deliveryTachom eter/Fuel Economy Gauge
                            Digital Clock
                            Multi Function Clock
                            22 7.5 Active Check Control
                            Front Parking Lights
                            Taillights
                            Front Side Marker Lights
                            23 7.5 Instrument Panel Lights
                            Taillights
                            Rear Side Marker/License Plate Lights
                            Rear Defogger
                            Multi-Function Clock
                            OBC
                            24 15 Turn Signals
                            Emergency Flasher
                            25 BLANK
                            26 BLANK
                            27 30 Interior Lights
                            Central Locking
                            OBC
                            Radio Amplifier
                            28 30 Lighter
                            Power Antenna
                            29 7.5 Left Fog Light
                            30 7.5 Right Fog Light
                            • GunMetalGrey
                              • Dec 2010
                              • 1499
                              My standard running lights Brights.
                              wtf
