My FX-R Projector Retrofit Thread
  • tightithrash
    • 200
    #106
    amazing work. subd. love lights done correctly. please sell these. i would totally be on board.
    • bmwman91
      • Oct 2004
      • 3134
      #107
      Originally posted by straight6pwr
      been waiting a while to see that part done. very cool!
      also, the aluminum tape has work 100% perfect for my retrofit, although as you say does not look OEM. the key was recreating vents at the OEM locations. when I inadvertently closed all the vents on my first retrofit, it caused moisture to get trapped inside and had no way to get out. its impossible to seal them 100% so use vents to your advantage.
      not sure if OEM hella/bosch euro projectors have the vents, but my DEPO brand ones did.
      Good to know, didn't think about moisture. I was thinking about small vents just for heat purposes, but trapped condensation is also an issue now that you mention it. Yes, the housings had vents, but they were all chopped off when I modded them. As of now, aluminum tape looks like it is going to be the way to go.
      Transaction Feedback: LINK
      • santas"e30"
        • Dec 2013
        • 14
        #108
        Wow crazy write up I would be more then happy to send you a new set of lights once you get these completed :)
        Sent from my HTC One using Tapatalk
        • clavinZERO
          Hella sick E30
          • Mar 2004
          • 2027
          #109
          Subscribed. So close I can taste it. I would be SO in for a purchase if these end up being made and sold for all Ellipsoid variations (smiley, non-smiley, US, Euro, etc.)
          Been waiting on something like this for years.
          "BMW Style 32 Poster-Child"
          HTTP://WWW.CLAVINZERO.COM/e30-5-lug
          **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
          • george graves
            • 19998
            #110
            Yea. As it turns out....You can't seal moisture out of a large enclousure, unless you have a good surface area of a gasket (not an o-ring) a large area.
            Who ever designed the BMW outside air temp sensor thought they could, and that why they always fail. (I encapsulate mine - and that's why they never fail)
            But.......have you looked into the "snorkel" of the OEM headlights? I think there is more to it than that? Other then just an air way - I think they did something....Maybe a compound that prompts humility to transfer in and out? Any guesses? I'm lost on it.
            Originally posted by Matt-B
            • Wh33lhop
              • 11705
              #111
              No BMW has ever had any degree of humility.
              paint sucks
              • DER E30
                • Sep 2013
                • 2349
                #112
                Hahaha
                -Christian
                • glucklich21
                  • 1912
                  #113
                  It's literally a bunch of plastic balls inside a tube. This is why I like the Bosch bucket over the Hella bucket. The vent is built in. No weird snorkel thing to protrude out the backside. Perfect for retrofitting
                  However Hella's design is better. The contact of all of the balls closes up most of the gaps that water could pass through. Instead of having a few non direct openings to the outside, you have tons. The vapor can still escape while keeping other bits out too.
                  The Bosch's design downfall is the opening is about 5mm in diameter. While not directly exposed to the outside, air gets in. What travels with air is dust. The inside of Bosch's can get really dirty (and full of dead gnats) as a result. Hella's don't have that as the balls act as a filter keeping most of the particles out.
                  • colombacho
                    • May 2007
                    • 391
                    #114
                    did this project die?
                    • eThirtyAaron
                      • Sep 2015
                      • 144
                      #115
                      Any updates?
