Rebuilding Euro Smiley Tips?
  • GOT8SPD
    • 270
    #31
    I tried putting it on the way you described and it was a PIA! So I did it the way I described and ran into no problems....luck of the draw I suppose..
    • rav320uk
      • Jun 2004
      • 1337
      #32
      Agreed, whichever way works i suppose.:p
      If you have bought items from me, please leave feedback below.
      If you are a BUYER, Check My Feedback.:up:
      http://www.r3vlimited.com/board/showthread.php?t=183860
      Check out my Euro Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=215557
      • GOT8SPD
        • 270
        #33
        What kind of grease did you use? We don't really have rust problems here on the Western United States =) These things came so rusted and beat from Germany....
        • rav320uk
          • Jun 2004
          • 1337
          #34
          Just normal bearing grease, run of the mill.
          Anything does over this side of the pond to keep the rain out.:up:
          • davericher20
            • 29
            #35
            Great advice itt, I recently took my lights out and found the drivers side is broken......the actual housing/bracket that screws into the frame of the car broke off.......Do I need another euro bracket? (It has the leveling adjuster as well) Or can I swap it for regular housing to save money?
            • rav320uk
              • Jun 2004
              • 1337
              #36
              Ni idea on how different the housings are.
              • davem
                • Jun 2010
                • 705
                #37
                so what is broken? if it's the:
                -plastic bucket with lense glued on then you'll need to get another one of those
                -it it's just the black mounting bracket you can use one from north american ellipsoids too, they're identical
                • Aleman
                  • Mar 2012
                  • 1598
                  #38
                  What type of adhesive should I use to glue the lenses back onto the reflector body? I have some clear RTV handy, but not sure it can take the heat when the lights are burnin' bright.
                  R135 /// 1990 Alpinweiß II 325is
                  └┼┼┘ /// 1993 Black/Black Convertible (sold)
                  ..24
                  • Onizukachan
                    • Sep 2012
                    • 163
                    #39
                    I used black windowweld... But I was smoking mine at the same time. You'd want something grey if you want it to match the others.
                    • Aleman
                      • Mar 2012
                      • 1598
                      #40
                      Alright, here's some good info from the Permatex website. I was looking for info on temperature range, and I ultimately went with the Ultra Gray Gasket Maker to affix the glass lens onto the low beam housing. It looks good to me, but I can't judge its durability just yet.
                      Permatex® Black Silicone Adhesive Sealant
                      Low odor formula! General-purpose, black RTV indoor/outdoor sealant. Seals, bonds, repairs, mends and secures glass, metal, plastics, fabric, vinyl, weather stripping and vinyl tops. Protects and repairs electrical wiring. May be applied to horizontal or vertical surfaces.Waterproof and flexible. Temperature range -75°F to 450°F (-59°C to 232°C); resists water, weather, and vibration.
                      Permatex® Clear RTV Silicone Adhesive Sealant
                      General-purpose, clear RTV indoor/ outdoor sealant. Seals, bonds, repairs, mends and secures glass, metal, plastics, fabric, vinyl, weather stripping and vinyl tops. Protects and repairs electrical wiring. May be applied to horizontal or vertical surfaces.Waterproof and flexible. Temperature range -75°F to 400°F (-59°C to 204°C); resists water, weather, and vibration.
                      Permatex® Flowable Silicone Windshield & Glass Sealer
                      Wicking action silicone “seeks the leak”. Flows into hidden and hard-to-reach areas. Forms a tough, waterproof, durable, clear seal that is resistant to weather, extreme temperatures, vibration, shock and most shop chemicals. Fills surface voids and irregularities. Temperature range -80°F to 400°F (-62°C to 204°C).
                      Permatex® Ultra Grey® Rigid High-Torque RTV Silicone Gasket Maker
                      OEM specified. Permatex® Ultra silicones were developed to meet today’s technology changes. Sensor-safe, low odor, noncorrosive. Outstanding oil resistance and joint movement tolerance. Eight times more flexible than cork/composite gaskets; three times more oil resistant than conventional silicones. Temperature range -65°F to 500°F (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
                      ..24
                      • Solarian
                        • Oct 2012
                        • 121
                        #41
                        Anyone else looking for these things, I found them on ECS Tuning for 38 cents a pop. Sadly it's 28 bucks shipping to Canada, but should be useful for you 'muricans.
                        http://www.ecstuning.com/ES2091906/
                        • GOT8SPD
                          • 270
                          #42
                          ^^^they also sell those on RM European. com
                          • Solarian
                            • Oct 2012
                            • 121
                            #43
                            How did you go about taking these apart without breaking stuff? I mean the adjusters, you use pliers, or?
                            • Aleman
                              • Mar 2012
                              • 1598
                              #44
                              Yeah, to detach the adjusters from the housing, you just pull 'em out of the sockets with a pliers. Just wrap the threads with a rag first, so you don't damage them...
                              ..24
                              • delamaize
                                • Nov 2013
                                • 1449
                                #45
                                Anyone actually get the part numbers for all the adjuster parts?
                                Dumpster Fire Pilot
