Using left blinkers flashes high beams also...
  • optimusp517
    • Oct 2005
    • 797
    I thought it was something wrong, but whenever I use the left blinker it flashes the high beams briefly and it does that everytime I use it. The right blinker is fine. What should I look at first to solve this cause I make a TONS of left turns and hate to see me high beaming someone everytime I turn left.
    Now this only happens when my headlights are turned on.
  • Jordan
    • 12916
    Likely a bad turn signal stalk switch. Easy to replace.
    https://mtechniqueabs.com/
    • Dave
      E30 RAT
      • 11675
      I have a spare one. $20 shipped if you want it.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • optimusp517
        • Oct 2005
        • 797
        Where's the switch located? Now you say easy? Is it just in and out? If so DaveCN I'll probably pick it up next week from ya.
        • Digitalwave
          is a poseur
          • 6299
          The switch is what you use to turn on the turn signals.
          RISING EDGE
          • Jordan
            • 12916
            :giggle:
            • parkerbink
              • Jun 2004
              • 10138
              Let me get this straight, You mean the turn signal switch turns the turn signals on and off?
              • Digitalwave
                is a poseur
                • 6299
                Would you like a diagram to explain? :?:
                RISING EDGE
                • optimusp517
                  • Oct 2005
                  • 797
                  I believe that's what they're saying :) The lever you'd use to turn left or right or use your high beams.
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Wow. Please I really need a diagram.
                    • optimusp517
                      • Oct 2005
                      • 797
                      This is the piece if I'm incorrect please let me know.
                      • parkerbink
                        • Jun 2004
                        • 10138
                        Thanks & how is it used?
