Euro Smiley Adjuster Screws
  • Klug
    • Sep 2011
    • 804
    ....why are you so expensive. They are impossible to find less than $10. I also did some searching around to see if I can source any screws that would work, but I came back empty handed. If someone has a 3D-printer, this would be the jackpot.
    Has anyone ever thought of an alternative solution? My headlights look like crazy eyes from Mr. Deeds.
    Part # 63121385397
    /rant
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
    • 37833
    $9.18 from TheBMWPartStore. I know, not much better! lol.
    You can always source some from a set of US ellipsoids. They are the same and are likely to be less rusty.
    Grover Beach, California
    BimmerHeads.com
    • bradnic
      • Jul 2012
      • 3554
      If you're replacing adjusters don't forget the plastic bits the adjusters fit in to as well. Just went through this on mine and most of the plastic parts were brittle and broken.
      part 11 on this realoem diagram 63121378369. 12 to a set
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • bmwman91
        • Oct 2004
        • 3134
        I just had to shell out like $110 for all new adjusters and spacers for my FX-R retrofit. I searched and searched for ball-ended M6 fasteners to no avail. If I ever get around to building my ball-turner for my lathe, it'll be less of an issue. Of course, the white plastic bits are usually trashed too, and they are sort of important, so the metal M6 screw part is only half of it!
        Transaction Feedback: LINK
        • jrobie79
          • Mar 2006
          • 2526
          $8.95 on bmwmercedesparts.com
          1991 318i ---- 308K - retired
          • eurolife
            • Jan 2013
            • 128
            How do I convert to these from hydraulic adjusters?
            • Spyke
              • Sep 2012
              • 494
              ^ I was wondering the same. I've cleaned up most of the adjusters on our e30 and replaced the plastic receptacle bushings, but those mechanical adjusters are just stuck in place (1 per low beam assembly). I can't get them aimed high enough due to those, everything else is working okay
              Current_SeeDee 1972 e10 Luna 1975 e10
              Past___Veronica 1994 e36 Le-Ah 1987 e30
