High Beam for Depo Smilys
  • Staszek
    • 2533
    So not sure what is going on here, I assumed the high beams were H1. They fit in the housing, but how do I connect them to the wiring?
  • reelizmpro
    • 9558
    If you put the bulb in, the red spade connector attaches to the bulb and the round terminal goes over the ground post to the left. Then on the other side of the cap, you can slide their wiring over the terminals or use the correct BMW style connector.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Staszek
      • 2533
      Thanks! That makes sense. Brainfart.
