independent foglights
  • husyrs
    • Sep 2007
    • 164
    Canada Rulez
    • husyrs
      • Sep 2007
      • 164
      Originally posted by atomic
      And you can choke on a dick too ...... Good luck with your searching that is if you will ...
      u the one who did start this so lets be a friends and help me out GUYS
        • 34844
        Originally posted by husyrs
        Canada Rulez
        so does downs syndrome, apparently.
        • e30s52
          • Oct 2007
          • 5235
          how about them km hour. eh how aboot that! lol cannada
          www.gutenparts.com
          • atomic
            • Jun 2007
            • 5691
            here http://www.r3vlimited.com/board/showthread.php?t=67337
            30 second search so next time please give it a try .... OK ?
            • husyrs
              • Sep 2007
              • 164
              :hitler:
              YOOOOOOOOOOOOOO U R CAR IS SEXY post pic please
              • husyrs
                • Sep 2007
                • 164
                THANKS BRO
                • Desaevious
                  • Aug 2007
                  • 3810
                  Lol, newbs.
                  SC*AR (Schwarz Army)
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    In all seriousness, the early cars are different, and require a different procedure, has to do with switched vs constant power, plus differences in the switch itself.
                    Being a douche and expecting help based on the kindness of complete strangers usually results in disappointment though, as in this case. (esp around here, which is why I love this place)
                    -Dave
                    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                    Need some help figuring out the ETM?
                    • husyrs
                      • Sep 2007
                      • 164
                      like yours right
                      • DaveSmed
                        • Apr 2007
                        • 1407
                        Yes. I took mine off because the bumper mounted fog lights look like crap. However, you want to have yours on for god only knows what reason without the headlights on. (oh, I forgot, it looks cool )
                        Whatever. Don't be a douche.
                        Pull out the relay (K8) and bend pin 85 flat facing in towards 30. This is to prevent it from making contact to the fuse box terminal. Now solder a jumper between the bent pin and pin 30. Sweet. Almost done.
                        Now pull your steering column lower cover off, the one over the pedals. Unplug the foglight button and look at the plug. One terminal should have two wires, and one should have one. Cut both wires that go to the same terminal about 3 inches back in the harness. Connect the two wires you just cut that run into the harness together. (don't be ghetto and twist and tape) Now connect the wires that go into the switch to a good ground.
                        Now anytime you push the button, you'll be able to be identified as the owner of a car with a dopey ass bumper from a longer distance. Yay?
                        -Dave
                        • husyrs
                          • Sep 2007
                          • 164
                          hahahaha thanks man BTW what relay is that k8 or k4
                          • husyrs
                            • Sep 2007
                            • 164
                            BTW our loonie is > than yours ...Bahahahaha
                            • DaveSmed
                              • Apr 2007
                              • 1407
                              k8.
                              Now go away. This thread is retarded enough.
                              -Dave
                              • colombacho
                                • May 2007
                                • 391
                                i cant believe this guy is getting off this easy.
                                Whaa, whaaa, Help me, i am special whaaa.
