DDM Tuning HID Kits - Apexcone - $55 is that right?
  • winfred
    • Apr 2008
    • 72
    #106
    galvanized steel from lowes, its thin enough that it can be worked without real trouble, i matched the contour of the front of the wheel wells and used a scrap piece and rivets to reinforce where i had to split it to get the contour right
    Originally posted by Kwaaahhh
    Thanks man! That looks really good, what is that made out of? I don't even have the center oem dust shield.
    • vte30
      • Jan 2009
      • 15
      #107
      T Verdier, great post about having to reverse the connectors. A couple minutes ago I installed my kit (55w slimline) and pulled the light switch... nothing!
      I panicked a little and then ran inside and did a search... found your post and now everything works! Thank you very much!
      • e30s52
        • Oct 2007
        • 5235
        #108
        I just got a set of Euro bosch smoked headlights. I need h1 right?
        www.gutenparts.com
        • Gooch
          • Dec 2006
          • 1674
          #109
          Yes, H1. Correct.
          '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
          '87 535i - Vacuum brake conversion [SOLD]
          '93 525iT - 5-speed swap - 320k and counting
          '09 328xi - 6-speed
          • accident
            • 7303
            #110
            are you guys ordering the raptor slims or the apexcone 3/4? Apexcones are like $77 to my door, and they're in san diego!
            Moral of this story?
            • ian e30 318is
              • Mar 2007
              • 1809
              #111
              just installed the apexcone kit from ddm in my euro ellipsoids. 55w 5k. couldnt be happier with the result. not too blue and really f'in bright. just had to do some drilling with the spade bit through the plastic. thanks for the help too andy
              1991 LS1 Swapped 318is
              Instagram:
              https://instagram.com/saltybeast/
              LS Build Thread:
              https://www.r3vlimited.com/board/for...s-e30-ls1-swap
              • dannyg
                • Mar 2007
                • 1553
                #112
                Waiting for my kit to come in...Now I just have to figure out how to wire these in to my Smoked Hellas...My car came with sealed beams from the factory...? Any tips?
                1993 325ic Schwarz/Natur
                1991 318is Black/Black - Slicktop - Project s52
                1989 Alpine White/Black M3 S52
                1988 Henna/Pearl M3 <3
                • ian e30 318is
                  • Mar 2007
                  • 1809
                  #113
                  are they euro ellips or us? both are pretty easy. for the euros just twist off the black caps on the back of the lights. then take out the existing bulbs by unclipping them and pulling out the two small wires (should be a red "hot" and a black "ground"). you will need to drill a small hole with a spade bit (maybe .5in or so) through the black cap to put the hid bulb through and to put the rubber grommet on. the ballast will just plug into the bulb and the bulb will just plug into the two small wires. then just attach the ballast to your car so it doesnt move around. i used velcro. then your ready to roll out 8-)
                  Instagram:
                  LS Build Thread:
                  • dannyg
                    • Mar 2007
                    • 1553
                    #114
                    they are euros...right now on my vert there are sealed us beams...how will I wire up the ddm slim ballast kit to work in the euro ellips?
                    • ian e30 318is
                      • Mar 2007
                      • 1809
                      #115
                      so you dont have them in your car already? hear is an install write up on how to put in the euros... http://www.r3vlimited.com/board/show...ing+ellipsoids
                      then just follow the directions two posts up. if u need pics i can get you some. just let me know. i need to find my camera though. haha
                      Instagram:
                      LS Build Thread:
                      • lowlightbw
                        • Mar 2008
                        • 668
                        #116
                        i need to get a definitive answer. im going to install the 55w 6k ddm 9006 kit into my US ellipsoids tonight and im wanting to confirm that it is indeed just plug and play. i know the fogs/euro smilies/etc require drilling, splicing and whatever else. will i need only a few screws and or velcro to secure the ballasts? thanks ahead. flame suit on.
                        www.benjamineliward.com
                        • BrewCity11
                          • Mar 2008
                          • 2335
                          #117
                          Yes, plug n play. Like posted above, there is a chance you may need to swap wires (black and red). i just installed two DDM kits, in an Acura and a Nissan, and the Acura needed the wires swapped, but the Nissan didn't.
                          turk@gutenparts.com
                          • lowlightbw
                            • Mar 2008
                            • 668
                            #118
                            thanks for the quick response. hoping to just play and blind.
                            • straight6pwr
                              • Sep 2004
                              • 3450
                              #119
                              got the 35w 4300k 9006 kit for my u.s. spec ellips. they are amazing, and will never drive another car without HIDs. t
                              • joonsup
                                • 776
                                #120
                                I installed a set of 35w Apexcone hid kit for my e30 a few weeks ago and the ony reason why it was plug n play was b/c I bought a set of adaptors from matt on this forum for $20. I am not certain, but if you don't have those adaptors you will need to do some cutting since stock lights are sealed beam connectors? Correct me if i'm wrong.
                                In regards to the hid lights I kinda want to try out the 55w to compare the two. The 35w are bright, but not as bright as the hid's on the e90 and e92s
