LOUD static when adjusting volume
  • Lippy
    • Jul 2022
    • 95
    I bought a "new" OE E30 head unit on ebay last year. I doubt it was actually new, but it did come in the original box and was in incredible condition. Everything on it works, but often when I adjust the volume it makes a VERY loud static sound.
    Anyone have any suggestions on how to fix this? Do you think there is anything I can do?
  • 82eye
    • Jan 2009
    • 2012
    it's a dirty volume pot. try cleaning it with canned air / electronics cleaner. if it doesn't work the pots can be replaced if you are good with electronics or take it to a custom audio shop.
    • Lippy
      • Jul 2022
      • 95
      82eye do I just spray right at the base of the volume knob? Do you know if the volume knobs pop off? Thanks!
      • 82eye
        • Jan 2009
        • 2012
        no experience directly with the e30 radio. just other electronics. i'll start removing the pot knob and spraying from outside. if that doesn't work i'll progress to taking the covers off. if that doesn't get it i'll replace the pot.
        • reelizmpro
          • 9533
          I actually pulled the knob and used WD40 (didn't have contact cleaner) and it fixed the issue. Just try to get it inside while turning the pot several times. If necessary, remove the radio and clean it with the radio upright. I've done this on an OEM BMW Alpine and aftermarket Kenwood.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
