HID: Load Resistor
  • Maddog
    • Dec 2006
    • 116
    HID: Load Resistor
    I finally bit the bullet and installed a Morimoto HID setup using its own relay harness. As part of it, I installed in parallel a 50 watt 6 ohm load resistor to avoid a low beam check light; HID lamps are 35 watts.
    The load resistor seems to overheat after the lights running for 15-30 minutes and the circuit triggering the low beam out light, but after works again after cooling off. The resistor is mounted on a metal surface.
    Has anyone experienced this? I plan to replace the load resistor and if it still persists to upgrade the resistor to a 100 watt 6 ohm.
    Appreciate your feedback/insight.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5585
    I use these and never get any kind of indication unless a light is actually out
    https://www.morimotohid.com/morimoto-canbus-2-hid-harness?quantity=1&utm_medium=cpc&utm_source=googl e&utm_campaign=22430343077&utm_content=_c_&gclsr c= aw.ds&gad_source=1&gad_campaignid=22430344715&gbra id=0AAAAAoSgE2_2tmaOrKQ5DFZCoKWBmOq9K&gclid=CjwKCA jw-rTUBhAiEiwADv8gBJnawndZgcLsogMjcjq7w2_9CddIDIbj9IL t8qQDp9zzsKb0DZmwgxoC1AcQAvD_BwE
    • Maddog
      • Dec 2006
      • 116
      Thanks MrBurgundy. Will give it a try.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5585
        np my guy
        • reelizmpro
          • 9551
          I have 15 year old DDM HID units that don't trigger the bulb out warning when turned on. I'm surprised the Morimoto's don't have load resistors built in.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • Maddog
            • Dec 2006
            • 116
            Hopefully, the Morimoto harness will be able to manage the heat. I will see how hot it gets and may consider placing a 2”x4”x1/4” aluminum plate between the sheet metal and unit to help dissipate heat.
