head unit wiring + fader delete
  • mccor023
    • Jul 2011
    • 683
    #46
    I did not test speaker wires. Don't know how to, I used your post on the 1st page in this thread and your sticky to match up wires.
    I love that people ask stupid questions so I dont have.
    • mccor023
      • Jul 2011
      • 683
      #47
      After goofing around a little I am now rocking out on 3 speakers. I used the fader/balance in the new head unit to confirm. Perhaps the wires at the speaker are loose, I didn’t get a chance to check before the storm. Here’s what I did:
      Dash Speakers Head-unit
      Yellow/Red-LF+
      Yellow/Brown-LF-
      Yellow/Black-LR+
      Yellow/Brown-LR-
      Blue/Red-RF+
      Blue/Brown-RF-
      Blue/Black-RR+
      Blue/Brown-RR-
      I capped 1 Gray/Red that was with the fader speakers.
      Red/Green (12v) Yellow
      Violet/White (Acc.) Red
      Grey/Red (ill.)
      White (amp remote) Blue/White
      The 2 brown (ground) wires I had coming out I spliced into 1 and then into the Black wire of the head unit.
      • StereoInstaller1
        GAS
        • 22679
        #48
        Yellow/Red-LF+
        Yellow/Brown-LF-
        Yellow/Black-LR+
        Yellow/Brown-LR-
        Blue/Red-RF+
        Blue/Brown-RF-
        Blue/Black-RR+
        Blue/Brown-RR-
        Grey/Red (ill.)
        Perfect...now swap a different speaker with the dead one, might be done!
        Closing SOON!
        Thanks for 10 years of fun!
        • tdennehy
          • Sep 2012
          • 6
          #49
          1990 e30 BMW convertible stereo options
          Greetings! I was wondering if you could point me in the right direction since I've read many of your posts and you seem to be the most knowledgable one out there!
          My "stock" 1990 BMW e30 manual top convertible would love to have a new stereo. I took her to a stereo shop here in Folsom, CA, and the guy looked at it and told me that isn't the original stereo. It reads BMW on the cassette door, and I bought the car from the original owner, and he told me the car was stock.
          That said, my last 1986 e30 had an amp in the back. I didn't see one in this car when I refurbished the antenna last year. The trunk is smaller, etc, because she's a convertible. I haven't removed the kick panels yet to see how many wires go to the speakers - I'm assuming I don't have premium sound because of all your other posts I have read.
          Long story short, I was thinking that if I could find a stereo from a later year BMW that had CD changer integration, I could buy it and integrate an iPod into it instead of the CD changer. What I was hoping for was an easy "remove old stereo and plug in "new to me" stereo and then add the iPod integration. I tried one of those FM broadcasters - it sounds pretty lousy.
          Do you have any advice for me?
          OK, stop right there.
          If you have a non premium sound car, you do not need (nor would I recommend) to run new wires...everything you need is already in the dash.
          That diagram you made in the OP is WRONG, and will smoke your deck after a while, plus it will sound really shitty.
          Ask "Danny" what a difference it made, I did his in 15 minutes while we were at the Picnic.
          Here is what to do:
          1. Remove deck
          2. remove fader
          3. unwrap wires to the fader, about 8 to 10 inches before the plug.
          You will find 2 sets of 3 wires, all brown, or like brown/orange.
          These are your speaker negatives.
          Now, use yellow/red for the left front positive and the wire it is twisted with is the ground for that speaker.
          Yellow/black will be the left rear positive, the twisted wire is the ground for that speaker
          Blue/red is right front, again with the twisted wire thing...bet you see the pattern now, dont'cha?
          Seriously, if this takes you half an hour, I would be amazed.
          You will also see how the 2 blue wires feed into the fader, and the chassis ground.
          If you see a grey/red wire, that is the dash light circuit. Cap it off, you won't need it.
          BTW, the stock 20 year old BMW wire is excellent, use it in good faith.
          • StereoInstaller1
            GAS
            • 22679
            #50
            If you are referring to "faking" the deck into thinking it has a changer, please let me know how you did it.
            In the verts, the amp is located under the cover, against the front wall of the trunk, on the left side of the car. Same amp, same colors as far as I know.
            Closing SOON!
            • cool breeze
              • Dec 2015
              • 15
              #51
              Yellow/Red-LF+
              Yellow/Brown-LF-
              Yellow/Black-LR+
              Yellow/Brown-LR-
              Blue/Red-RF+
              Blue/Brown-RF-
              Blue/Black-RR+
              Blue/Brown-RR-
              Grey/Red (ill.)
              SO after much searching this was the info i needed because my car had already been hacked multiple times. I have sound from all 4 speakers but if i fade either side the speakers begin to crackle. Did i wire correctly?
              • cool breeze
                • Dec 2015
                • 15
                #52
                soo anyone?
                • lemansguy
                  • Nov 2013
                  • 205
                  #53
                  stock head unit?
                  '87 BMW 325i - ground control c/o, condor bushings, 16x8/16x9 wheels - SOLD
                  '09 MazdaSpeed 3 - FOR SALE
                  • StereoInstaller1
                    GAS
                    • 22679
                    #54
                    No, it means you likely have a shared speaker negative somewhere.
                    BTW, they are not "grounds" they are either negatives or "returns", but they are not in contact with chassis ground, thats why the distinction should be clarified.
                    Lets first start off this: with what year and model is the car?
                    There have been 5 basic wiring topographies used in E30s, starting with year and model helps nail down which is which.
                    It does not help at all that BMW doesn't seem to use exact dates for the wiring changeover, but it narrows it down a lot.
                    Luke
                    Closing SOON!
                    • cool breeze
                      • Dec 2015
                      • 15
                      #55
                      Hmm ok well i am unfamiliar with returns as opposed to grounds. my 12v knowledge is recent.
                      1987 325e non-premium system i believe. only 4 speakers
                      Aftermarket headunit, some basic clarion, new
                      • StereoInstaller1
                        GAS
                        • 22679
                        #56
                        Yeah, you need to run new wires, no way around it, unfortunately.
                        However, you can do just the fronts, but at this point, its way easier to just run new.
                        Closing SOON!
                        • cool breeze
                          • Dec 2015
                          • 15
                          #57
                          well shit, installing for a friend who has been happy as it is currently so i guess its staying that way. thanks for the help!
                          • StereoInstaller1
                            GAS
                            • 22679
                            #58
                            Here;s a cheap and easy way to tell if it's correct on pretty much any install: run the fader and balance through their range, and they should work as expected. If they get crackly or act weird, its bad wiring.
                            Closing SOON!
                            • D.Martijn
                              • Sep 2016
                              • 1024
                              #59
                              Bumping an older thread,
                              I'm currently figuring out if it would be posslible to delete the fader as I would like the extra spot in the center console for an oil temp which is build into an original switch.
                              Like you, Luke, stated, there are 3 yellow and 3 blue wires + a ground and grey/red wire coming to the fader, one blue and yellow go the the radio, it only has 2 channels.
                              Could I delete the fader and run both front and both rear speakers to the designated channel without the fader?
                              1990 325iX Touring - November 2018 R3V Car Of The Month
                              1980 Volkswagen Golf mk1 1.1
                              1974 BMW 2002 Touring
                              Instagram
                              • george graves
                                • 19997
                                #60
                                Yes you can. Delete that little knob. Trace wires and have fun.
                                Originally posted by Matt-B
