Shorted My ratchet on my starter
  • SocalianSD
    • Jan 2010
    • 152
    I shorted my ratchet on my starter on accident. Now my windows won't work, also my blower motor, heated seats and A/c button. I swapped out the k5 and k7 load relays with known working relays and checked all of my fuses none of them are blown. My windows still won't work! Is there a common ground that could be fried for all of the stuff i mentioned above?? Help!!!
    6287156541_32b0c468f4_z-1 by SoCalian_SD, on Flickr
  • 5Toes
    • 9836
    Curious about this too, I may have done the same sort of thing
    • AndrewBird
      The Mad Scientist
      • 11898
      Possible fried the fusable link in the trunk that is connected to the battery.
      • SocalianSD
        • Jan 2010
        • 152
        Thanks for the advice Nitro, But my battery is in the engine bay and I already have cleaned up my terminals. My ratchet shorted on the green black wire and the power cable. I got under the dash yesterday and checked the common ground next to the steering column and I couldn't find anything unusual. It's acting like all of the stuff I mentioned above are all on the same circuit.
        • bimmerteck
          • 762
          Originally posted by NitroRustlerDriver
          Possible fried the fusable link that is connected to the battery.
          ^Fixed.
          I would start by checking the fusable link as well.
            • 34844
            this is why you unhook the battery before working on or near electrical connections.
            • MoreMayhem
              • Feb 2012
              • 650
              Should design a switch that disconnects the Negative from the battery whenever the hood is opened. Maybe some already has? I'm guilty of leaving the battery connected when it should not be, but with no disasters fortunately. It is a habit that needs to be broken.
                • 34844
                that sounds like a bad idea - how would you run the engine with the hood open? every time you change your oil, or check the level, your radio, clock, and DME reset?
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Sounds like the ground on your starter lost connection. There are 2 small wires on the starter and if the ground is disconnected things act funny.
                  john@m20guru.com
                  Links:
                  • MoreMayhem
                    • Feb 2012
                    • 650
                    I am ripe with bad ideas! But like you said, battery should always be disconnected when working on or near electrical components.
                    • Gregs///M
                      • Mar 2012
                      • 2459
                      Also check your engine to chassis ground from the oil pan to frame rail. Should be clean, tight, and not oily or corroded.
                      Owner - Bavarian Restoration
                      BMW and European Electronics Repair and Restoration
                      www.BavRest.com
                      My Feedback Thread
                      Our Facebook!
                      Follow our Instagram!
                      • cabriodster87
                        • Jan 2011
                        • 1042
                        First thought.
                        Reich und Roll!
                        • GOT8SPD
                          • 270
                          ^^^LOL At least you know! I don't know it's a bad idea till it's actually gone terribly wrong and there's no return...
                          • DaveSmed
                            • Apr 2007
                            • 1407
                            Ya nuked that little terminal internally inside the starter.
                            When it shorted, that little stud was trying to power the starter motor.
                            Move the black/green wire over to the other little stud, and all should be well.
                            -Dave
                            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                            Need some help figuring out the ETM?
                            • SocalianSD
                              • Jan 2010
                              • 152
                              Update!
                              Ok I forgot to mention(on purpose) that I was changing out my starter to a new one and I didn't disconnect the battery. Yes i know I'm an idiot and know better.
                              Anyways, the first starter had the problem and I thought it was something to do with the wiring since all my fuses and relays were good sooo I tore into my dash. Everything is good, Ok went and warrantied out that starter and got another one.... same Issue. So I grounded the wire to the body of my car and everything works now.
                              My question to all of you guys who remans starters besides Cardone? Also where could I get a starter that wont give me this problem? The first starter was from a place called Metro and the second one was from Autozone.
