HIDs no work
  • deutschman
    • May 2008
    • 5958
    HIDs no work
    Sorry for this thread guys. I checked out all the HID install guides and I am sure I am doing everything right. Still no worky. The one thing that could be holding me up are my 7.5 fuses. How ever they are not blowing. Could the stop my HIDs from working, but not blow?
    I have DDM 35w thin ballast kits on both highs and lows on my '84 325e using adapter plugs for the 9006 and 9005 bulbs in my US lights.
    Ballast wiring
    High beam (black to brown, red to yellow)
    Low beam (black to brown, red to wires closest to black/brown)
    Any help? Will installing 10amp fuses fix this?
  • deutschman
    • May 2008
    • 5958
    Never mind. I found a short in the headlight switch. FUCKIN BITCH
    • Rubes
      • 295
      how were you able to fix this? seems like my low beam isn't working anymore but my high beam is.
      • deutschman
        • May 2008
        • 5958
        Just wire them like I did and use 10amp fuses. Check your light fuses. If they are 7.5 amp change them.
          • 34839
          why would you need to change your fuses?
          • deutschman
            • May 2008
            • 5958
            I have read in multiple places that the ballasts draw a good amount of power on start up and that 10amp fuses handle it better.
              • 34839
              no.. not needed. 10 amps likely won't hurt anything, but generally increasing the fuse size isn't a good idea as the wires are sized to a specific current. if you increase the fuse size too much you're just increasing the chances of wiring damage or a fire.
              you won't likely blow a fuse with a stock 7.5a fuse either. if you are then it'd have to be a really poor quality ballast.
              • Gregs///M
                • Mar 2012
                • 2459
                I would not recommend you change your fuse sizes ever. The 7.5A fuses should be able to handle the additional current draw from the ballast. You were blowing fuses because you found a short in the wiring.
                Installing a 10A fuses increases your change of electrical fire.
                I'm running 35W ballasts on my 7.5a fuses fine. My e34 had 55W ballasts on the 7.5A fuse fine.
                For anyone recommending to just replace your 7.5A fuse with a 10A fuse is doing it wrong. If you blow 7.5 amp fuse, you MUST install a fused automotive relay to switch power for the ballast. Its the safest way.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • FLG
                  • Sep 2011
                  • 3165
                  55w and 7.5 all good
                  Btw ddms are crap (I knew this but needed lights) ballast crapped out month or two later. Just ordered a good quality set from the retro fit source.
                  Sent from my Galaxy Nexus using Tapatalk 2
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • Blackout
                    • Apr 2011
                    • 4125
                    I been using 7.5A. No issues so far.
                    I guess it would depend on the ballast type?
                    » PARTS FOR SALE
                    » TRANSACTION FEEDBACK
                    • deutschman
                      • May 2008
                      • 5958
                      Well shit. I guess I can change back to my 7.5 fuses then. Cant trust the internets
                      As fare as DDM, yes they are generally crap. How ever, I had a set that lasted me years and on top of that I am on a strict budget and they were less then a set of good regular bulbs which seam to be around $60 most places. So I feel fine about running them. If I had a nicer car and more money I would buy more expensive shit.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        Stay away from a crappy swap and you wont have issues.
                        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                        • deutschman
                          • May 2008
                          • 5958
                          Never had issues with the lights. It was the e30 light switch that had a short. Read the thread man.
