New odometer gears, now my speedo is dead. What did I break?
  • ClayW
    • Apr 2011
    • 377
    I swapped in new Motometer gears from Garagistic, and now my speedometer is not reading. It's entirely possible that I either broke something or plugged something in wrong (or not at all. What did I miss?
    Also, there is a black, two-prong connector that fits into the green connector on the bottom of the speedometer. I'm not sure into which slot the black connector plugs. Does someone have a picture?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • reelizmpro
    • 9556
    Did you use the yellow rubber spacers that came with the gears to space them out so that the teeth mesh? If you didn't, then that's the problem.
    Oh you said the speedo isn't working. In that case you may have damaged the circuit board or solder joints while changing the gears.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Gregs///M
      • Mar 2012
      • 2459
      If your speedo doesnt work but your odometer does, you broke something. Take it apart and inspect. Maybe the needle is stuck on something or you did not put the odometer assembly back together correctly.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • ClayW
        • Apr 2011
        • 377
        Neither the speedometer nor the odometer works now. I'm thinking that I plugged something in worng or possibly broke something else. I'll be taking it out tonight.
        • JTDay
          • Dec 2009
          • 521
          Did you forget the wires that go into the green connector on the speedo?
          Past: 1987 325iS, Bilsteins - HR Sports
          Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
          2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
          • ClayW
            • Apr 2011
            • 377
            I plugged those in, but I'm not sure if they're in the right slot. Is there a picture of the right place in which to plug those?
            • Gregs///M
              • Mar 2012
              • 2459
              All the slots in the green connector are common with each other. Electrically all three are connected together so it does not matter which slot you use. BTW that wire is the speed sense wire for the cruise control so it wont have an effect on the speedo/odo.
              You need to verify you are getting speed signal from the differential sensor, to the cluster. This wire is brown/red in the white connector. You should see a 1.5-6 volts AC signal with a multi meter. Jack the car up and engage the rear wheels so they are spinning. make sure your meter is set to AC volts.
              If you see no voltage or increase in volts with wheel speed, the problem is the wires or rear diff sensor. If signal is there, the problem is in the cluster, which is most likely a broken solder joint on the cluster main board.
              GL
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
