can a bad SI board interfere w odometer?
  • cunninglinguist
    • Mar 2004
    • 281
    I just replaced all 4 gears in my VDO odometer. I can turn the gears smoothly by hand, but the odo doesn't work when installed.
    My SI board is flaky (I'm quite sure it's dying). Can a bad SI board cause the odometer to not work?
  • reelizmpro
    • 9558
    No, if the speedo works the odometer should work as well. If it doesn't, then there is an issue with the motor or the gears.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • AndrewBird
      The Mad Scientist
      • 11898
      The wiring going to the speed sensor in the diff often gets brittle and breaks, I'd start by looking there. If the speedo works however, then something else is wrong.
      • cunninglinguist
        • Mar 2004
        • 281
        OK, thanks guys.
        The speedo works fine. I guess I will have to look at the circuit board next.
        • Gregs///M
          • Mar 2012
          • 2459
          VDO gears are very easy to get backward. Make sure that you are meshing the gears together and not over tightening the cover.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
