I'm trying to diagnose my battery charging issue that I've been having. Hopefully I can organize this thread to help other people out too in the future. I'll Keep on updating the first post on my testing and findings.
Background: I'm not an expert on this stuff, I've been working on cars for a while now, but I don't have much experience diagnosing things, and it doesn't help that electricity has never been my strength
Problem: My car has always had a charging issue. It could probably go two weeks and the battery would die. To me this sounded like something was on the fritz since it wasn't constant. I could go 2 weeks, hell sometimes even a month and be fine. Now it seems like something is just down right broke, the alternator doesn't charge the battery at all. I can have the car fully charged via battery charger and I could probably kill the battery in a day if I tried.
Symptoms:
-Alternator Light in the SI board is on when the key is in the "ON" position and is still on after you start the car, but it is VERY dim and goes away after I give the engine just a little bit of gas. ABS light also does this as well.
-Battery doesn't charge. I use a battery charger to charge it outside the car and once I put it in, its only a matter of time until I have to swap it out again.
New Parts:
-Refurbished 150 Amp Alternator (eBay)
-Refurbished Gauge Cluster (Bavarian Restoration)
-Upgraded Power and Ground Cables (Bavarian Restoration)
-Used, but working 1.3 Motronic ECU (eBay)
Voltage Test:
Fully charged battery fresh off the charger - 13.07 v
Said battery hooked up to car - 12.99 v
Car on and rev'd a couple of times - 12.55 v
Lights on - 12.36 v
High beams on - 12.29 v
Car turned off after test - 12.69 v
Symptoms:
New Parts:
Voltage Test:
Lights on - 12.36 v
