battery parasitic drain
  • mickpNo6
    • Sep 2013
    • 5
    My apologies for coming very late on this thread however I just found it over the weekend while searching the web for E30 battery current drain issues.
    I was wondering if digger resolved this issue and what was the root cause as I have a similar issue going on in my car.
    Regards,
    Mick
    • digger
      • Nov 2005
      • 6017
      i never found a smoking gun i think the battery had been discharged and not recharged properly while at a shop and just need a proper deep charge, i did have a vaccum pump wired incorrectly which i fixed but it had been that way for years without major issue so wasnt the root cause.
      the last time it got drained was being towed when igntion was left on for a while about a year ago. i havent had any drain issues since it was recharged properly but havent checked the current draw.
      • mickpNo6
        • Sep 2013
        • 5
        Many thanks,
        I appreciate the follow-up response,
        I clearly have a different issue now as the fully charged battery is Ok but nothing is happening at the ignition key in the start position.
        Looks like another miss spent weekend coming up.
        Cheers.
        Regards,
        Mick
        • Seb325e
          • Jul 2020
          • 4
          Folks, if you dont mind me reviving this.
          i have a stock 325e from 1984. Battery dies in a short period of time. 178mA draw.
          removed all fuses and nothing changes
          in the junction, i disconnected everything and when connecting either the alternator/starter cable or the wiring harness to the engine/ecu/etc i get the draw.
          any ideas?
          i pulled the entire harness, cleaned every connector and ground, connected again and still…
          thanks in advance!
          • McGyver
            • 4536
            So with every fuse pulled, you still have 178mA draw?
            Time to use the Electrical Troubleshooting Manual to figure out what is directly connected to the battery that could be causing the issue.
            • jeffnhiscars
              • Jun 2011
              • 6010
              Have you bench tested the alternator
              Alice the Time Capsule
