Controlling stock oil temp gauge
  • BeirBrennerE30
    • 2740
    Hello r3v. I have an M3 cluster with the stock oil temp gauge. I am collecting date from the canbus (s54 swap) for logging and display on a custom Alpina style digital gauge and I figured since I had access to the oil temp canbus data it didnt make sense to install another oil temp sender on the engine.
    I know people have converted the econometer into boost gauges and stuff like that. What method of control was used for the gauge. Is 10bit PWMing a mosfet on the sensor line enough to drive this? I didnt want to reinvent the wheel since I know people are already doing this.
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
  • bmwman91
    • Oct 2004
    • 3128
    The econometer is controlled by two signals: vehicle speed and fuel injection duty cycle. The speed signal is routed internally in the cluster's main PCB, so that trace would need to be cut. It is a signal which is pulled-up to 12V and switched to ground by a reed switch in the differential. For the injector duty cycle, there is a pull-up to 12V on the input which is switched to ground in the ECU. The low-time matches the time that the injector is open.
    So for your application, you would want to feed one of these a constant duty cycle signal and then vary the other. It'll take some experimenting to figure out the right values.
    Transaction Feedback: LINK
    • BeirBrennerE30
      • 2740
      Thanks for the reply. I think the oil temp gauge is different and has a separate power, ground and then the sensor signal. The sensor being a normal thermister temp sensor. So I guess its about how best to replicate that temp sender.
      e30sport.net
      • reelizmpro
        • 9477
        Yes, it does...power/ground/sender. Order up a factory M3 temp sender and install it.
        88 M3 - LACHSSILBER/SCHWARZE
        • bmwman91
          • Oct 2004
          • 3128
          Ah, sorry, I thought you were trying to repurpose the econometer. reelizimpro has it right for using the other analog gauges.
          Page 6210-2 shows how the oil temp gauge is connected.
          All other E30 wiring diagrams:
          • george graves
            • 19993
            I'd be surprised if it was a reed switch.
            Originally posted by Matt-B
            • BeirBrennerE30
              • 2740
              Alright I used a transistor and had a microcontroller PWM it and I can control the oil temp gauge now but it is a little jumpy. Granted there is only 10bit resolution and its not linear on the gauge. Probably not a big deal because over CAN it is only 8 bit resolution for oil temp from the MSS54.
              Anyone see an issue with this setup or a better way to do it?
              e30sport.net
              • e30davie
                • Apr 2016
                • 1788
                I assume it originally worked on resistance of the oil pressure sender. How about one of these suckers or similar.
                Potentiometers are incredibly useful, whether you're controlling the volume on your stereo or the 'mood lighting' in your room. The problem with traditiona
                Ive never used one, but if it does indeed work on resistance then i reckon it might be the go. That one is a 10k one. I assume you can get them in different sizes. if it were me i would get it working with a manual potentiometer first. then you know what size you need.
                Alternatively if you already have it going with your pwm, can you put a capacitor on the output to help smooth it out?
                • george graves
                  • 19993
                  Digital pots are almost never the answer - in almost any circuit. They can only handle a tiny amount of current. And with anything automotive, you need to expect huch voltage spikes and even negative voltages. 100v volt spike or a -50v spike isn't uncommon on when working with automotive electronics.
                  • BeirBrennerE30
                    • 2740
                    Agreed with that. I may change out the transistor for a fet (any recommendations?). I have a 10ohm resistor inline with it so it never shorts out. Appears to work and likely more accurate than the stock sender would be.
                    Anyone see an issue I am missing?
                    e30sport.net
                    • bmwman91
                      • Oct 2004
                      • 3128
                      What is the PWM frequency?
                      How clean are the oil temp values given by the CAN bus? As in, do you need to do some digital averaging on the received values, or are they pretty well low-pass filtered for noise before the MSS54 sends them? I'd assume that the ADC input stages in the ECU have at least a little filtering on them, but who knows.
                      • george graves
                        • 19993
                        I'm a little confused what you're asking at this point. Is your issue driving the gauge? Or? Can we start over? :)
                        • BeirBrennerE30
                          • 2740
                          Sure. SO I built a gauge for the center vent like an Alpina gauge. Some of the info for it I am pulling from the s54 CAN bus (intake temp). I have access to the everything being sent on the CAN bus including oil temp. Oil temp is broadcast every 100ms in 8bits on 0x720. the 8 bits, bin->dec then subtract 48, corresponds to degrees C which the reading the ECU is using for oil temp. So if the ECU sends 0b11001000 = 0xC8 = 200 = 152degC.
                          I am running an e30 M3 gauge cluster that has the oil temp gauge built in. I know to get this gauge to function I just need to hook up the e30 M3 temp sender which is a thermister essentially. It seems wasteful to have 2 temp senders: one for the MSS54 ecu and data log, and another just for the gauge. Ideally I thought it would be more efficient to have the module that was receiving CAN and logging everything to control the cluster oil temp gauge so the temp displayed is the oil temp that the ECU is actually using. Sanity check on what the ECU is seeing as well as monitor oil temp
                          The microcontroller that I am using for the gauge has a PMW out for 10bit resolution. I have successfully used the PWM to drive a transistor on the signal line for the e30 M3 oil temp gauge and control it. So my next step was going to be to make a table to compare the oil temp I am receiving to what the PWM out should be.
                          The jump between pwm steps at the high end of the gauge, >210degF, gets a little choppy on the gauge. Its nonlinear from PWM steps to what is displayed on the gauge. But I figure that isnt that big of an issue since temps getting much above that mean I have bigger cooling issues.
                          For this thread I am asking for a sanity check if anyone has feedback or knows of a better way to do this. Or in the alternative tell me I am crazy and just to hook up the e30 M3 sender.
                          e30sport.net
                          • bmwman91
                            • Oct 2004
                            • 3128
                            So at the high temperature end, due to the non-linear transfer function, a one LSb change in the oil temperature value leads to a large jump in the PWM duty cycle / needle position? If so, there are a couple of fairly easy solutions since the needle is a relatively slow device (compared to the 100ms sampling period of the input).
                            What type of microcontroller are you using?
                            • bmwman91
                              • Oct 2004
                              • 3128
                              IIRC it was called out as such in my old Chilton's guide which I can't find. Searching around the web, it seems to be a common arrangement on older BMW's, including the E30. One of the two "prongs" in the sender contains a magnet, the other the reed switch, and when one of the vanes on the diff sender wheel passes between, it interrupts the magnetic flux and opens the switch.
                              /Hijack
