Ok i have on my 91 318is i have no green and black or green and purple wires in the harness running through the trunk. I have two green and red a gray and red and a gray and blue i believe. which wires on the car is the unlock and lock?
My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
Haha, some possibilities there... I'm getting another one and wiring it to the brakelights. I'll use it whenever tailgaters get too close. Downshift and flash the brakes, it'll blow their mind!
'88 325is
VP UT of Austin Autoholics
BMWCCA 380364Comment
Guys, has anyone wired the lights to blink with the keyless only unit? I tried to do it by splicing the wires behind the light switch and connecting them to the two empty wires on the transmitter. It did not work, they do not light at all when I lock the car. HELP ME!!!!!!!!!!!!Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
so no one then?Yours truly,
Rich
hey, i've had the omega keyless entry installed on my car for a few months now, but was wondering how well the range is on your guys'? Since I installed mine in the trunk, my remote only works about twenty or so feet from the trunk. Is there any way to possibly extend the range?
:(^SOLD^:(Comment
i installed one of these units on friday using the trunk method. for some reason i could only lock the car. unlock does nothing. i also can't trigger the central unlock at the trunk switch so something wierd is going on
today i relocated the unit to the kick panel and everything works as it's supposed to. module is velcro'd to the top of the abs computer. i have the dip switches in the "on demand" mode, not timed pulse as the timing was too slow to trigger the lock/unlock relays and i was too lazy to adjust the timing. range is as far as i need it to be.
two thumbs upJames
'88 M3Comment
I forgot to mention I picked up one of these and installed it in my '88 M3 not too long ago. My car was having the sticky door lock cylinder syndrome, and was taking a lot of force to unlock. I didn't really want to pull it apart to fix it, so for $30 and 20 minutes of total work I don't have to worry about it anymore!
For anyone with an E30, I think this is a must buy addition to your car.Eric Giles
'20 M2 CS
'04 M3
'11 X5 35D
'87 325is
'91 325i Sport
There are few things more expensive than a cheap BMW...Comment
I think this will be my next non-maintenence purchase for my beater if I plan on keeping it past this summer. I hate having to unlock from my trunk or passenger door. This would be a good addition.Originally posted by Eric GilesI forgot to mention I picked up one of these and installed it in my '88 M3 not too long ago. My car was having the sticky door lock cylinder syndrome, and was taking a lot of force to unlock. I didn't really want to pull it apart to fix it, so for $30 and 20 minutes of total work I don't have to worry about it anymore!
For anyone with an E30, I think this is a must buy addition to your car.Comment
I finally finished mine up, after making a BIG booboo.
I didn't use the other wire set and it worked fine... are they for somethign in particular that i would need, i figure as long as my car locks/unlocks i'm set, right?
PS- once i got over the booboo, simple install, yet still so proud of myself :-P another thing accomplished! and yes.. probably the best $30 i've spent on my car so far!Comment
ok, what the hell. all of a sudden my keyless stopped working. this after working perfectly for 3 months. central locking still works like it should
so i pulled the unit out, unplugged it, and plugged it back in. locks work again. however after letting the car sit for a an hour or so, it stopped working again. it's not a wiring problem. it's almost like the unit is malfunctioning. anyone else seen something like this?James
'88 M3Comment
