84 E30 M10 with 89 M20 swap. cluster question
  • Citron
    • Apr 2020
    • 32
    I have searched on here and Google, and the answers I find are very inconsistent.
    This is what I have. 1984 318 that the PO swapped a 1989 M20b25 into. The gauge cluster is shot, I need a new one. The existing is a vdo without a coding plug.
    I understand that I will need a pre facelift cluster because of the gas tank issue, unless I change the fuel gauge. I will also need a cluster from a 325i so the tach functions correctly. So I think I am looking for a VDO cluster from a 86-88 325i? Will a different cluster work? I am good with auto wiring, so if it is a matter of tracing and splicing wires to make a different cluster work, I can do that.
    Thanks
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4493
    Your current cluster has a rear coding plug.
    To my knowledge the early fuel gauge/sending unit stopped at 09/87. So you need a 7k tach, a front coding plug cluster frame (late model has check engine light, early front coding plug doesn't), and a 6cyl coding plug (1385468).
    *I think* '87 325i or '87 325iS cluster will be the only "full" cluster that'll work. VDO/Motometer are interchangeable.
    • Citron
      • Apr 2020
      • 32
      Awesome! Thanks for the info.
