How do I fix this window gap?
  • tonyloban
    • Oct 2013
    • 254
    I have followed the bentley but it's a little confusing. I adjusted the height, so it sits good at the top towards the front. But the rear side of the driver window is a tad bit heigher. Also, there's a gap between the window and where the window should rest when closed. From the rear, you can see the window is sticking out further.
    Maybe I have to adjust the door?
    What do I need to adjust?
    My Photography - http://www.flickr.com/photos/106236166@N06/ - My Photography
  • tonyloban
    • Oct 2013
    • 254
    • mitchlikesbikes
      • Dec 2013
      • 858
      how about shrinking and rotating those pictures so we can tell what the hell we're looking at?
      IG: @mitchlikesbikes
      • tonyloban
        • Oct 2013
        • 254
        There's a gap there. And the window trim at the bottom of the circled area sticks out a bit.
        • tonyloban
          • Oct 2013
          • 254
          I think the whole door doesn't close very tightly as it sits just a tad bit further out as you can see in the picture.
          • Das Delfin
            • Sep 2014
            • 2293
            ^ adjust the door latch so it sits further inside the car. Looks like you need to adjust the window a bit more so the top edge will seal. There should be a way to move the bottom end of the track outward, therefore moving the top of the window when closed inward. I remember seeing it in some pdf a while back.
            • uturn
              • Dec 2010
              • 995
              I have that same problem on my vert. Lmk when you find out how to adjust it.
              • reelizmpro
                • 9493
                Loosen the 2 torx bolts and adjust the door latch on the body.
                88 M3 - LACHSSILBER/SCHWARZE
                • tonyloban
                  • Oct 2013
                  • 254
                  The top seals in the front but not in the back. It sits a little higher in the back and doesn't get in there like the front. Is my door sagging? Because if I line it up with the seal, then it isn't parallel with the rear window
                  • tonyloban
                    • Oct 2013
                    • 254
                    What bolts exactly? Car noob here.
                    • tonyloban
                      • Oct 2013
                      • 254
                      • tonyloban
                        • Oct 2013
                        • 254
                        I think I move this in, right?
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          ^ yes, that. That should solve both your problems. If that doesn't work then there may be something askew in the door latch itself (the one mounted on the door)
                          • mr.vang
                            • 4371
                            This air jack https://www.google.com/search?q=emer...23064360064440
                            A locksmith used this on my wife's car and now the door has a small gap, very similar to yours. It also created wind noise inside the car.
                            • MoreMayhem
                              • Feb 2012
                              • 650
                              If the door skin lines up smoothly with the body, I doubt it's the latch or catch. I just adjusted the passenger side windows, font and rear, on my vert. Gap wasn't as prominent, but I was getting an annoying rattle. I followed the steps in the Bentley and didn't have any trouble, but did have to read it several times before I understood it. For some of the adjustments you are supposed to use a special tool to hold the adjuster Allen in place while tightening the nut, but it's possible to do it without.
                              Edit: just looked more closely at your photos again. Your latch and catch probably do need adjusting.
