Rear passenger floor wet. Where are the rear drains?
  • reelizmpro
    • 9543
    It doesn't rain much here but when it does, my rear passenger carpet gets soaked. I once noticed water dripping past the top seal, onto the seat and trickling down into the carpet. I fixed the seal but the carpet still gets soaked seemingly from underneath. I suspect water is getting in from the rear quarter glass seal since there is a small gap between it and the window glass where it meets the door. I just adjusted the window so the seal presses up against the glass and I hope this does the trick. Anyway, I'm curious if there is a drain for the rear quarters? is it a slit by the seems under the doors? Thanks.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • fight4life28
    • Apr 2014
    • 821
    Could it be the drain for the rear cover that hides the soft top. They have drains at the bottom (Front towards the softtop mounts) and sometimes things can get stuck in there causing the water to come from only the rear of the car...Leafs, Dift , what might have been on your soft top over time.
    • cWalk3r
      • Jun 2014
      • 178
      Check the body plug in the floor to see if its in place properly
      • flyboyx
        • 8371
        faulty tonneau cover drains will drip water into the trunk.
        the window to body seal should drip water into the cavity between the quarter panel and metal structure in the inside of the rear window. my guess would be the door seal itself if you are sure it isn't coming from the b pillar seal.
        i suggest, taking out the rear seat and the passenger seat. pull up the carpet on that side of the car. sit inside the car in the back and have your wife spray the garden hose on that side of the car. you should be able to see where its coming in this way.
        Gigitty Gigitty!!!!
        • fporro
          • 1859
          • reelizmpro
            • 9543
            So my passenger side rails were gunked up with oil/roadgrime, etc. I've had an oil leak from my remote oil filter adapter for years which I finally sorted out a few months ago. I ran a coat hanger up and cleared the drains. I don't know if they were fully clogged but I cleaned them up the best I could. I think the main issue was the window seal and the rear window alignment. I'm going to hit my seals with some conditioner and see if I can soften them up. New seals are expensive but I may just have to grab some. Thanks for the tips guys. I couldn't find much about vert drains online. Will update this thread later.
            88 M3 - LACHSSILBER
            • Das Delfin
              • Sep 2014
              • 2293
              new rear window vertical gaskets helped my issue with water on the rear floorboards. But the convertible top in the rain is a continuing struggle
              • cory58
                • 1021
                the drain under the top frame mount being clogged is what caused my passenger rear floor to get wet.
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                2015 328i - Euro Delivery/Performance Center Delivery
                BMWCCA
                E30CCA
                • reelizmpro
                  • 9543
                  From what I understand, that isn't a drain. It's a hole that's supposed to be covered up by a label. The drain is elsewhere.
                  88 M3 - LACHSSILBER
                  • rcsoundn1
                    • Nov 2012
                    • 3361
                    I have this exact issue. what do you mean pass side rails were gunked up? I would realy like to fix this. I did look for the top storage drains quickly but did not see them. I assue I need to remove the seat to find those correct?
                    • mr2peak
                      • 2388
                      Anyone have a digram showing all the vert drains? My car is 100% naked underneath, perfect time to clean them all out
                      Drive it hard. Maintain it well.
                      A Topless Memorandum
                      • reelizmpro
                        • 9543
                        Check out FPorro's video. It shows one of the aft drains. There's two cutouts where the sill seams are that drain any water that's in the sills. Jack the car up and get under it to see them. I couldn't tell where they were just by feel. Make sure they are clear with a coat hanger or wire. I don't believe my top storage compartment drain is clogged but it's worth checking as well. I think what it came down to on my car were the rear quarter window alignment causing the window seal to not touch the glass in some areas and the vertical glass seal as well. The seals are old and broken on mine.
                        88 M3 - LACHSSILBER
                        • cory58
                          • 1021
                          That's news to me. I haven't worried about it since I freed up garage space for my 'vert (approx. 6 years ago), but when I was dealing with the wet floor, I read several threads about the drains under the top frame. Guess I need to do some more research. Where are the drains in the boot well?
                          Thanks, Cory
                          1992 325i Cabrio
                          1988 320i Touring
                          2000 M5
                          1977 530i
                          BMWCCA
                          E30CCA
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            Boot well has at least one drain at the forward end of it and it's guaranteed to be plugged and I think there's a second one aft. The rockers have about 5 on each side at the pinch weld that are about 1/2"X 1/8. They typically plug from the outside due to chip guard, road crud, rust etc. I opened mine up with the smallest screw driver I had then double checked after I redid the chip guard with SEM.
                            Having said that I don't see how water gets in to the rockers but the drains mere existence suggests it's possible.
                            Alice the Time Capsule
