NEW Deck Lid & Soft Top Struts Have Arrived !!
  • BaltimoreBimmer
    • Apr 2016
    • 307
    #46
    Any pictures of these installed? Just popped out to my cabrio to see what's what and couldn't really visualize where they go
    • parkerbink
      • Jun 2004
      • 10138
      #47
      Originally posted by jeffnhiscars
      Ive sent a PM to everyone who has expressed interest and not yet purchased. All paid orders are shipped.
      Great! Looking forward to them!
      • jeffnhiscars
        • Jun 2011
        • 6010
        #48
        photobucket is giving me grief but if you raise the back window and look down where the top bolts to the body you should have one strut on each side. they slide in the plastic sleeve which is included
        Alice the Time Capsule
        • gart
          • Jul 2012
          • 295
          #49
          Received the package today. Thanks for doing this!
          89 325 cabrio in progress m52tub28 swap
          99 540it
          86 Volvo 240 wagon
          99 Cherokee
          13 Passat
          • jeffnhiscars
            • Jun 2011
            • 6010
            #50
            Here is where the top strut sits
            There's a ball socket at the bottom which has a pin that's a bit awkward to remove as it's deep in the hinge mechanism. I used a metal BBQ skewer to pop it free. From there it's easy to fish out
            To reinstall I put some grease in the hole to hold the pin while I lowered the strut in to place. Then carefully pried the socket over the ball with a large screwdriver. If you get that done without dislodging the pin, it's easy enough to pop the pin back in place with the same screw driver
            Note the chunk of broken plastic sleeve sitting under the socket. That's what 30yo plastic likes to do
            • jeffnhiscars
              • Jun 2011
              • 6010
              #51
              • jeffnhiscars
                • Jun 2011
                • 6010
                #52
                The upper end is your fairly straight forward pin & clip mechanism only you are securing the sleeve not the strut. The strut slides freely in the sleeve with the back half of the top flipped up so they zero tension when installing these
                Don't forget to pry out the tab with a small screw driver or hook so it clears the pin. Don't just pull on the clip or you might damage it
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  #53
                  So remove the old clip, detach upper end of sleeve and remove old assembly. Install new strut on ball socket, snap pin around neck, slide new sleeve over it and reinstall sleeve pin.
                  Repeat on other side and your done.
                  • parkerbink
                    • Jun 2004
                    • 10138
                    #54
                    Got mine today, turns out my car was converted from electric top and did not have them at all.
                    I no longer have to hold the lid.
                    Thanks!!!
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      #55
                      Thanks!!!
                      yet another selling feature on these...no hard hat needed when raising and lowering the top.
                      You're welcome !!
                      • parkerbink
                        • Jun 2004
                        • 10138
                        #56
                        The top struts were alternative fun doing. The passenger side had a little circlip instead of the big full size clip in your picture on top. I was glad when I found the big one on teh driver side until it fell and disappeared.
                        I had to scour my fasteners to find another.
                        • cspec
                          • Apr 2017
                          • 182
                          #57
                          Very interested! Just wondering the difficulty in the install?
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            #58
                            Glad you found one. For future reference Ace Hardware is a good source for hard to find fittings.
                            On a scale of 1-10 I'd say the hinge shocks are a 4 just use it's fiddly and the deck lids can't be more than a 1-2 with 10 being a ball buster and 1 being something you can do with your eyes closed.
                            As a reminder, always install gas. struts with the piston down. There's oil inside to help keep the seals from drying out. Done ask me about Bilsteins :)
                            • DRVN2WN
                              • Jan 2017
                              • 39
                              #59
                              Got mine in the mail. Once I have some spare time I'll get them mounted up and, if I'm feeling bold, I'll make a DIY guide.
                              drvn2wn
                              • cspec
                                • Apr 2017
                                • 182
                                #60
                                Please do so! I'm kind of tired of holding up the lid with my head...
