Vinyl adhesive residue
  • Escaport
    • May 2017
    • 62
    I've changed my interior since the original was falling apart. I am changing the color completely, so the blue indigo vinyl that was covering the tonneau cover I have removed because it didn't match. I've decided to leave the tonneau just painted since I like that style. I'm having a hell of a time removing all the leftover adhesive though. Has anyone done this and have any tips or tricks?
    So far I've tried microfiber cutting pads with compound on a DA polisher. Goo Gone. Bug and Tar remover hand rubbed. The current leader has been bug and tar remover, but after three hours of work, I've gone from the driver's side to just behind the rear driver's side headrest area. It's painfully slow and I'm now running into larger amounts of adhesive in the middle of the cover, so it's even slower going.
    Current - 1991 E30 325i Auto Vert, 2013 F30 335i M-sport, 2014 F25 X3 M-sport
    Past - 1986 E30 325es, 1988 E30 M3, 1991 E34 535i 5sp, 1991 E31 850i 6sp, 1992 E36 325i, 1995 E36 M3, 2000 E46 323i, 2009 E60 535i, 2011 E90 335d
  • ejs999
    • Mar 2006
    • 70
    I mostly used goo gone when I redid mine this summer - it helped doing it in the sun and letting the goo gone sit on it for awhile. I also tried 90% alcohol. I found that solvent worked better in the final cleaning than the goo gone, I think it was paint prep cleaner on a cloth. I also used a plastic trim tool to scrape the softened glue off of the paint
    • Northern
      I like cupcakes & sh!tboxes
      • 5217
      I've had great luck removing adhesives with 3M's pinstripe and adhesive remover spray. I know there's also a smaller version in a black can, but I have this one: https://www.amazon.ca/3M-08908-Woodg.../dp/B000PENLSE
      Originally posted by priapism
      Originally posted by shameson
      • cory58
        • 1021
        How about an adhesive removal wheel that you use with a drill?
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        2015 328i - Euro Delivery/Performance Center Delivery
        BMWCCA
        E30CCA
