Exterior mirror caps and trunk third brake light removal.
  • GOZER
    • Apr 2024
    • 11
    I have a 1989 325i convertable and the paint on the plastic of the exterior mirror caps and the third brake light are bubbling and look really gross. I was wondering how you can remove these parts safely so I can paint them. I cant find another post about removal of just the plastic pieces. Thank you the help! REPOST
  • reelizmpro
    • 9556
    The plastic on the side mirrors cannot be separated easily. I suggest removing the entire housing and painting it...just remove the glass and mask the motor. The 3rd brake light on the decklid has like 6 hidden screws from underneath. Be careful to remove them all before trying to pry the housing or you will break the brittle plastic. I believe the housing is actually secured by 4 of the 6 screws but I don't remember which.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • GOZER
      • Apr 2024
      • 11
      Thank you for the info! For removing the mirror cap do I remove it from where it mates the car or do I go from the bottom and take off the mirror and such?
      • Robert Fisher
        • Oct 2009
        • 45
        I painted mine while on the car. I sanded off the bubbles and smoothed the surfaces on the outside. Then masked the rest of the door and threw a blanket over the rest of the car. Turned out pretty good. T he main thing I had trouble with was the color. It is surprising how many different colors there are of white...
        Bob
        Bob in Arizona
        • cory58
          • 1021
          Remove the entire mirror from the door. There are DIYs and videos.
          1992 325i Cabrio
          1988 320i Touring
          2000 M5
          1977 530i
          2015 328i - Euro Delivery/Performance Center Delivery
          BMWCCA
          E30CCA
