Timing Belt / Water Pump DIY - Step by Step Pictures
  • burlmays9
    • 227
    #166
    If you get the alternator belt tight it will hold the pulley from moving and then just keep the alternator from spinning and you can get the fan off easy.
    Edit: I didn't realize how difficult people make this job haha
    • JinormusJ
      • 6887
      #167
      Like I said
      Mechanics absolutely love to over torque the fan clutches. Even a light-as-can-be alternator belt will slip (believe me, I've tried)
      But you are forgiven, because I cannot stop staring at this:
      • burlmays9
        • 227
        #168
        Haha alright it might not apply in all cases but it worked just fine for me. I was going to suggest welding a steel rod to the pulley but that's just overkill
        • Butler
          • Nov 2009
          • 1613
          #169
          I'm doing this and spilled coolant everywhere. Plastic drop cloth and a storage bin should be added to the list.
          And kity litter
          Fuuuuuuuu
          -Nick
          Originally posted by 87e30
          First of all: calm the fuck down; second of all; cool story bro.
          • gmont02@yahoo.com
            • 53
            #170
            Man i just did my head gasket and i cant figure out why it won't start now WTF? Besides from what I already how to fix next (crankshaft seals) this happens to me =(
            Any help?
            As I try to start it up the car the Idle Control Valve hums even if the key isnt turned. Makes me wonder if that killed my battery in the past.
            Anyways, is there something i may have for gotten to do? I have double checked my work, triple (quadruple) check. I had to just to make sure TDC was correct.
            For a reference on what a Idle Control Valve is here is a link:
            It sits right next to the throttle body.
            http://www.turnermotorsport.com/p-18...0-e34-e32.aspx
            '87 cabby parting
            sigpic92' calypso cabby preparing for storage
            • long tall eta
              • Jul 2010
              • 1536
              #171
              Any help?
              all the grounds conected? the strap from the block?
              • rhett325i
                • Jan 2005
                • 575
                #172
                I just did this project this weekend. Thanks so much for taking the time to document the process.
                • 2blue240
                  • Jan 2013
                  • 32
                  #173
                  Will post pics for my little trick to direct the coolant to a drain pan from the block, doing this and more tomorrow. Great write up btw
                  • long tall eta
                    • Jul 2010
                    • 1536
                    #174
                    wish i wasn't combing coolant out of my hair right now.:(
                    • mcr_driver
                      • 4491
                      #175
                      Could use a bit of help. started a TB diy and now no start :(
                      • Bmwb
                        • Jan 2013
                        • 196
                        #176
                        https://www.facebook.com/video/video...ideo_processed
                        u check the CPS ,
                        Sold Black BMW E30 325IS
                        1987 bmw e30 euro part out
                        1990 Bmw 325i Cabrio 2.9
                        Metric Mechanic 2.9 stroker
                        Holset Hx35w CXRacing Manifold
                        MegaSquirt ARP HeadStuds
                        OEM HG AEM Methanol injection
                        20psi
                        • Chriskbmx
                          • Apr 2012
                          • 972
                          #177
                          he said he has, it does fire on the first cylinder.
                          • mcr_driver
                            • 4491
                            #178
                            CPS was working prior to timing belt I don't have a spare to try against but I did have spark on cylinder one as mentioned above, and it is in the right spot.
                            • efficient
                              • Feb 2012
                              • 3312
                              #179
                              i started doing the timing belt on my friends e30 and i noticed when the head is at tdc and the crank is ahead . could this explain why his idle is at 1k-1.5k all the time and smelling lke gas all the time. im kinda worried if i set the crank on bdc its going to run weird. any suggestions?
                              btw what kinda sealant are you guys using for the water pump?
                              • estoguy
                                • May 2013
                                • 1087
                                #180
                                Great thread. Needs to be stickied.
                                Couple of questions myself. I'm planning on doing my TB soon. Do I really need the thin wrench? I tried an UltraPro 32mm, and it seemed to fit on the nut nicely and only costs about $20. Thoughts?
                                Estoguy
