hmmmm i didn't bleed mine at all.
Timing Belt / Water Pump DIY - Step by Step Pictures
Originally posted by R32toE30 View PostI dropped my radiator fan when I was trying to unscrew it. It broke a blade off. Can I still use it????sigpic
Originally posted by McGyver View Postyou realize it will be incredibly out of balance and spinning at a minimum of 600 rpm every time your car is on, right? no. buy a used one at a junkyard and next time be careful.
Also, as long as your cooling system is in check, you should be able to run w/o the fan until you can replace it, although you probably shouldn't do that for too long. I know a lot of the fan clutches are bad on these cars, so they aren't doing a whole lot anyways...sigpic
Originally posted by 91greg325i View PostThats a good point that I definitely didn't think about. Although the blades are such a small portion of the overall rotating mass, it may not be as big of an issue... Still, be careful.
i would say that it would be a bad idea to run it like that when you can just go to a junkyard and get another one.sigpic
Originally posted by McGyver View Posthow much mass is each of the weights on your tires that keeps it in balance? 5 grams on a 10lb wheel with another 10lb of rubber?
Bottom Line: Replace the fan.sigpic
Originally posted by R32toE30 View PostIm locating a local fan as we speak. I am better off just removing until i get the new fan?
Ill hopefully have a new one within the next week.sigpic
I drove from LA to hollywood with a broken blade and the fan was off balance enough to chew up the radiator hose.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by Cha Ching View PostI'm LOL'ing at all the hoopla...Yes, replace that sucker since being in balance is what motors are all about. I think I may even have a spare. Shoot me a PM & give me your address. You just need the fan, right? Your clutch is still good, just the blade broke, right?
