Your handiest tools
  • kronus
    • Apr 2008
    • 13028
    #31
    ball joint separators just like that are 15 bucks at harbor freight
    cars beep boop
    • dougie30
      • Apr 2012
      • 1708
      #32
      Originally posted by dothadance
      animal kotulak multi tool
      +100
      M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
      • 5Toes
        • 9836
        #33
        My $12 harbor frieght wobble extensions set. SO nice to have... has helped me a ton
        • 1987_325is
          • Jun 2010
          • 106
          #34
          snapon 7.2v 3/8 electric impact, but if your only using it to work on e30s then dont be lazy like me.
          • kwill22
            • Apr 2009
            • 962
            #35
            got the same set. i love it
            DENY IGNORANCE!
            Schwarz 325-totaled
            brilliantrot 318i-daily
            Originally posted by mkcman17
            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
            • apexhero
              • 32
              #36
              +3 on the pb blaster.. stuff works miracles on bitchy bolts!
              • Boise
                • 212
                #37
                Originally posted by TurboJake
                By far, the handiest tool I own is an air compressor.
                When I bought my compressor I knew I would use it more than I expected. I have used it WAY more than I ever could have guessed. Air tools are the best.
                • spike68
                  • Apr 2009
                  • 1185
                  #38
                  Fucking tacos.
                  Makes a job so much easier.
                  I don't even own this car anymore, but I'm too lazy to change the picture.
                  • xAZxE30x
                    • 1241
                    #39
                    1/2'' electric impact! I do not know what took me so long to get one
                    • Pudmunkie
                      • 210
                      #40
                      Originally posted by Danny
                      1/2" electric impact.
                      qft. dont know how i lived without mine... and ive always had air too!
                      sent from technology with science
                      • kumulonimbus
                        • May 2012
                        • 178
                        #41
                        Noob question-- what are some things you use air compressors for?
                        1990 BMW 325i Coupe
                        • Mr_Tripp
                          • Jun 2012
                          • 663
                          #42
                          Kobalt extreme access
                          • kts
                            • Jun 2010
                            • 753
                            #43
                            anything that you have an air tool for. :)
                            i mostly use it for the following:
                            - air impact to remove highly torqued/stubborn nuts/bolts (SO much easier to pull a trigger vs getting a breaker bar and/or cheater bar, especially in tight spaces) and then put them back on
                            - refill tires
                            - power my cut off wheel to cut the crap out of metal like it was soft butter
                            - helps make my plasma cutter work. :twisted:
                            a few of my friends use their air ratchet for removing pretty much any bolt, some use their compression them for painting, the list goes on and on.
                            • Wanganstyle
                              • 2828
                              #44
                              matco 6mm nutdriver for bmw hose clamps.
                              • Sailor37
                                • 985
                                #45
                                My most used/useful tools
                                --air compressor
                                --3/8" air ratchet
                                --1/2" drive breaker bar
                                --electric drill & 3/8" drive adapter for running shit in/out----use this a LOT
                                --floor jack/jack stands
                                --multimeter
                                --screwdriver magnetizer
                                --gear wrench set
