OKay I understand that it could be frustrating to not have the photos on here for you to follow. Not my fault as you can see Photobucket wants me to pay now for their service. But I want to help the community so I made a video of the whole install. Just pause or rewind if it goes too fast to read.
Thanks for visiting.
My car before install
Brand new spanking new
Figuring out where to fit all clips
Test fitting the whole thing.
NOTE: Make sure you tape both pieces TOGETHER.
Otherwise, you will get this gap
Marking the tip of the clips so it transfers to the body.
Drilled out a hole with a 3/8 step drill
Inserted the grommet
Tap tap tap
Tadah!
Installed the bottom clips
Lined up right
Making a hole for the rivet
Lined up perfectly the second time around
My riveter is too small for the BMW rivet
Temporary fix
If you are interested in the side skirts, let me know.
Tap tap tap
Tadah!
Lined up right
Temporary fix
