HOW TO: Installing IS Side Skirt
89 E30 S52
Transaction Feedback. -
Well gentlemen, I've changed my mind on the 3M double sided trim tape.
When I installed the first skirt on the passenger side, two of the green grommets pulled out of the hole, creating large, ugly gaps-see photo. I don't know if this was because I had painted my rockers with two coats of POR 15 and that made the seating area of the metal thicker or what, but needless to say, it really pissed me off.
Since I had already drilled all the holes on both sides, I went to Home Depot and found some plastic 3/8" plastic hole plugs and used rtv sealer on them and plugged the holes tight on the driver's side, letting it cure overnight. I left the white grommet (fits 5/16" hole in the rearward part of front fender and fits the round white plug) in place, as for some reason it seated well on both sides. That means you still have plugs in the front and the two plastic rivets in the rear wheelwell in place. I cut tape to fit the tabs where the plastic clips previously were, stuck one side in place on the skirt, leaving the protective strip on the other side. I then dry-fitted the skirt with the help of my wife to check fitment and determine where exactly to place the skirt for final installation. This is important--once the tape is stuck, it's stuck! Then it's just a matter of lining it up and pressing it on, again using a helper. Came out perfect and held fine at highway speeds on my way to the Windy City BMWCCA VintageFest last weekend. Now I've just got to redo the passenger side cause that gap is driving me nuts. Hope this helps.
I cleaned the very top most section with acetone and ran the tape the entire length. My skirts have never moved. The tape the way I did it also stops debris from running down and sitting inside the skirts. To help install the tape, apply the tape to the skirts keeping the backing on it then install the skirts with all the plastic clips on the pinch seam at the bottom. Finally gently pull the backing between the skirt and car. Pull down the length of the car while pressing the skirt to the car. Pretty easy. Prep all surfaces first and you'll never have to mess with them again.Comment
for guys using the 3M tape, how are you prepping the surface? alcohol or grease remover? 3M tape may work with spoilers but something like a side skirt it is prone to impacts into snow, curbs, potholes, debris in the road. Say goodbye to the skirt if it falls off in motion.Comment
I cleaned mine with denatured alcohol--but why are you bothering asking if you think the tape won't hold?for guys using the 3M tape, how are you prepping the surface? alcohol or grease remover? 3M tape may work with spoilers but something like a side skirt it is prone to impacts into snow, curbs, potholes, debris in the road. Say goodbye to the skirt if it falls off in motion.
I since have heard from two others who have used tape and had no issues whatsoever. Besides, I used the two rivets in the rear wheelwell and the plug in the front, and you've got the clips all along the bottom edge, so the tape is really only holding the top edge in the middle of the skirt.
And I don't drive my car in snow, onto curbs, or into potholes. ;)Comment
Like TrentW said..for guys using the 3M tape, how are you prepping the surface? alcohol or grease remover? 3M tape may work with spoilers but something like a side skirt it is prone to impacts into snow, curbs, potholes, debris in the road. Say goodbye to the skirt if it falls off in motion.
Its only holding the top to the body, not holding the entire skirt on. I had to remove my right side once due to having the fender repaired from a guy hitting it. The tape was tough to break loose. Factor in the clips on the pinch seam and its nearly indestructible.Comment
Good ideas, guys. It's all a matter of preference.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Transaction Feedback.Comment
89 E30 S52
Maybe. Last I heard he had a limited number and had sold them allComment
everyone gets them the same place... so NLA.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
89 E30 S52
