Let me get this right you weld your shock/strut to the tube?
Rear air bag install, Front air bag strut build on a e30.
Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot you -
I welded the tube supplied with the kit to the strut housing. just like the bc coil setup. Then you weld the shock to that tube. If you want low like my vert. You need to cut the tube off the strut housing flush at the bottom and pretty much the shock will sit flat right on that once everything is welded up.Comment
How did it handle?- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plateComment
So thats full lift? I may have to cut a bit higher than you, not trying to rattle my teeth out when i have to scoop up the grandparents or something. When aired out, were you at 0psi, or did it lay out before the bags were fully empty?
And im glad you addressed the handling woes that so many anti-air people have flooded the internet with.
BTW, what are you rocking now if you sold this setup?Comment
Im on ground control coils with chopped housings.
Yes, as soon as I hit the ground it was under 5psi. so I guess pretty much zero.Comment
Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
what about your oil pan would it ever hit the ground when you slamed it?sigpic www.camberwears.com Team16Niss-Meguiars-Underground Grafix -MediagearboxComment
so then did you still run a shock in the rear? or is it not needed?-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
