How to: Tell what head an M20 has, the 2 second way.
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Yeah yours is an oem head the 885 casting mark on the sides proves it
    88 325is Five Speed
    Lachssilber
    • cabriodster87
      • Jan 2011
      • 1042
      I just found that i have the AMC head. It's like my baby is sick now.
      BMW how could you let this happen?
      Reich und Roll!
      • MattAvino
        • Jan 2011
        • 2147
        so if you have an 87 325i with a "2.5/2.7" embossed head and torx headbolts you know they were changed at some point.
        The m20b25 I just pulled from my '87is has the '2.5' over the '2.7' stamped on the head. So has the head been replaced in the past?
        E30 buildy things
        http://www.r3vlimited.com/board/showthread.php?t=195286
        • reelizmpro
          • 9481
          This or the entire engine.
          88 M3 - LACHSSILBER/SCHWARZE
          • MattAvino
            • Jan 2011
            • 2147
            Very interesting, my motor or head has under 200k then.
            E30 buildy things
            • reelizmpro
              • 9481
              Probably snapped a timing belt before or overheated.
              • markt51
                • Apr 2012
                • 329
                87-88 cars came from the factory with 885 heads embossed with "2.5" only and hex headbolts. Even if your car was a super ETA 2.7 liter. 89-on heads had "2.5/2.7". These are the original specs, so if you have an 87 325i with a "2.5/2.7" embossed head and torx headbolts you know they were changed at some point.
                I have a 1989 325i, manufactured in 9/88 and my head only has the 2.5 on the circle and not 2.5/2.7. Is this the original head? or was it replaced with an older one at some point?
                89 325i Coupe Auto Delphin Metallic - Sold
                91 325i Sedan Auto Brilliantrot - Sold
                83 323i Euro Coupe Manual Lapisblue - Sold
                89 325i Coupe Manual Delphin - Sold
                89 325i Sedan Auto Brilliantrot
                87 325i Vert Manual Brilliantrot
                • mr.vang
                  • 4371
                  my eta head doesn't show what you had presented
                  • reelizmpro
                    • 9481
                    Probably was changed but I'm not sure of the exact cut off date. Take a pic of the engine bay for me. Does it have torx or hex headbolts?
                    • blueapplesoda
                      • Dec 2005
                      • 1904
                      I'm assuming for those of you who have the machined down nub where it should say 2.5//2.7 or 2.5, the reman co machined the exhaust manifold mating surfaces down.
                      Sort of like the tell-tale casting dots on the bottom of the cylinder head, block mating surface, to tell you roughly how far the head is machined down. I believe there are 3 stages of dot depth, but I may be wrong. I have to look, i just know that once all those dots are gone, the head has been "used up".
                      • actletpone
                        • Oct 2013
                        • 20
                        There is a head at my local bone yard which has the circle like the amc head. It does not have the other cast circle with 2.5/2.7 stamped on it, instead it has a bit like the eta at about cylinder 2 which just says 2.5. On the intake side it has 885 and the BMW enmblem. It is on a 1986 325.
                        What does this mean? Is it a 2.5 eta?.. can it be put on a 1990 325i ?
                        • 702pjc
                          • Sep 2012
                          • 143
                          I too have both the indentation mark and the 2.5/2.7 nub
                          • meengreene30
                            • Mar 2012
                            • 369
                            My 731 head i'm running.
                            • whodwho
                              • Jun 2008
                              • 1547
                              Those are not the intake ports of a 731 head unless it has been port matched to a 325i manifold
                              My M20 Frankenbuild(s)
                              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                              • meengreene30
                                • Mar 2012
                                • 369
                                Porting might have been done not sure. we were stumped with this motor too, came with a 272 cam, hd valvetrain. After a lot of searching we came up with it being a modified 731. Either way i'm really happy with this setup whatever it turns out to be, pulls a lil harder than my buddies 2.7i with same cam and valvetrain running headers.
